Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-14-2010, 12:06 PM
  #3466
Trader Rating: 62 (98%+)
Default Shock oil
Anyone know a good Losi shock oil weight for the TKI? My Track is Trax 70 if you've ever heard of it.......its hard, pretty flat, some big jumps, and a rough section or two wit some technical stuff.
yamahamxracer is offline
Old 07-14-2010, 02:14 PM
  #3467
Hi Guys,
Might of missed it but does anyone know what the RRP will be for the new TKI2 kits
I've seen them in Japan with pricess but wasnt sure if anyone in the US had idea too.
carlin is offline
Old 07-14-2010, 02:58 PM
  #3468
In sweden the price will be around 7500SEK, thats 1000$ and atm the std TKI costs 8500SEK=1150$ and the SE is around 5000SEK=700$
That should give you an idea.
(ofc Swedish prices are much higher but the relationship between TKI, TKI2 and SE should give you an idea of US price)
uhh, and yeah, i hope you guys get why we buy things from the US.....
Martin.S is offline
Old 07-14-2010, 05:44 PM
  #3469
pitpop's Avatar
Originally Posted by yamahamxracer
I know this is probably a stupid question, but I just picked up a mp9 off here and I was wondering if you have to use kyosho clutch shoes, or could I use dynamite max life or any brand?
I have to tell you, I do not advise mixing and matching clutch parts. Kyosho has a very good clutch, and if you do anything unusual, it can cause problems. Many people that I help have tried to use different parts only to have issues. All they had to do is go back to the standard clutch parts and it was perfect again. The tolerances are very close and the designers and racers work hard to get it just right, and our clutch is National Champion this year, so why mess with it?
I can tell you that the new silver shoes (IFW339) last longer, more than double the life of the blue aluminum shoes. You can use them, then remove and debur the edges with a file and reinstall them. Just run them until the spring rubs on the bell, they last a long time. If you are careful removing the springs you can also reuse them, but you can't bend or stretch them at all.
pitpop is offline
Old 07-14-2010, 05:47 PM
  #3470
pitpop's Avatar
Originally Posted by Wilson Picaldy
Any one know how to reinforce the wing? mine seems pretty easy to crack and bent
Hi Wilson. We have boiled the wings before, and it helps quite a bit.
pitpop is offline
Old 07-14-2010, 06:54 PM
  #3471
Originally Posted by WINTER350
Based on a Yen to dollars conversion thanks to IPOD, he is what IPOD says the value is...
TKI 31782 SE 31783 TKI2 31785 (Kit) / TKI2 31784SpecA)
123,900 \ 84,000  \ 92,400 /  \96,600
$1,343.00 $910.00 $1,001.00 $1,047.00
Please don't shoot the messanger, this was just an IPOD conversion of funds. I am assuming these are MSRP prices....
FYI for those asking
WINTER350 is offline
Old 07-14-2010, 07:02 PM
  #3472
Pit Pop - You might have some input to this back at Kyosho and this is just an idea. But coming off of rookie year going into my second year, I would love if Kyosho provided some kind of set up dvd to help those who bought these top quality MP9 kits. It just might help some of us rookies set up the car and stand a better chance of putting the car out front. Here on the east coast there are not many Kyosho drivers at my local track to help with car set up. 0 to be exact. I have earned the sole Captain Kyosho title at our track. Any hints or tips on how to do set ups would be awesome. Hoping maybe you can take that message up the ranks for us MP9 owners to the brass at Kyosho.
Thank you for your possible consideration of this request.
Old 07-14-2010, 07:19 PM
  #3473
Jammin57's Avatar
Trader Rating: 120 (100%+)
Just buy the hudy setup book it will tell you what everything does
Jammin57 is offline
Old 07-14-2010, 08:18 PM
  #3474
Ya vie tried the kyosho shoes and another 4 kyosho guys two sponsored and none of us run the stick shoe, it lasts..about 3 qualifiers then one shoe for me always starts to stick, I file the sides down, use the small shoe washer everything and they get hung up. I can see 110% using the Kyosho flywheel, collet, clutch bell & nut but the shoes shouldn't cause any problems unless you don't drill them the correct diameter, then you will have problems, I've seen guys use the kyosho clutch all the time on AE buggys and truggys for the ease of getting parts.
If anyone needs kyosho clutch shoes I have a bag of shoes ranging from a race or two on them to one qualifier and new if your interested send me a PM, most of them are the silver shoes too.
Andy
02maxima18 is offline
Old 07-14-2010, 08:22 PM
  #3475
I run 40wt losi in the front, 30wt in the rear losi oils, and my difffs are 7k front, 7k center, 3k rear, and put my steering turnbuckles the furthest back on the Ackerman plate. Doing the 7k in the front and the turnbuckles I gained too much steering off power lol, with the right tires it balances it out for a perfect set up for a tight technical track, I run on a med size bumpy, few bigger jump track with good traction with caliber m4 & gridiron SS or S.
Andy
Old 07-14-2010, 09:55 PM
  #3476
Thanks for the input guys! I'll definitely stick to the Kyosho clutch. And I'll give the 40 up front and 30 rear a try.
Old 07-14-2010, 11:46 PM
  #3477
Ya I really like the 40wt up front, 35wt for a smoother flat track, and in the rear 30wt is good I have 35wt in the rear on my SE "standard" buggy and that seems good, I thinking about going with 30wt the rear sesmed a little loose.
Andy
Old 07-15-2010, 12:44 AM
  #3478
Jammin57's Avatar
http://rcspecial.com/news/?p=52304
Jammin57 is offline
Old 07-15-2010, 06:54 AM
  #3479
Thanks for replying pitpop.
And I have little stupid question here, do fuel line arrangement could affect engine performance?
Wilson Picaldy is offline
Old 07-16-2010, 01:49 PM
  #3480
Originally Posted by Jammin57
Mmm interesting, but i would rather have mine as kit get it quicker & build it myself.
Hope they get released soon, reckon it will be after the WORLDS though as this is usual case with Kyosho
carlin is offline
