Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-05-2010, 10:51 AM
  #3421
pitpop's Avatar
Originally Posted by Wilson Picaldy
guys, how long is the turn buckle to get 0.5* and 1* toe out? don't have any toe gauge thanks
wow, that's a tough one... I doubt you would get two aswers the same. In off-road, there are so many variables with the suspension travel and free play, I doubt it's possible to provide an answer. We just eyeball it. Set the car down and look at it from above. If you have a very slight amount of toe out, you should be good. If you can tell the difference between .5 & 1 degree of toe out, you better get yourself to Thailand and run the Worlds.
pitpop is offline
Old 07-05-2010, 12:04 PM
  #3422
afr0sch's Avatar
Trader Rating: 95 (100%+)
sounds like you need a setup station...go get one and let us know what the measurements are so we can stop using our eyeballs.
afr0sch is offline
Old 07-05-2010, 01:29 PM
  #3423
a setup station nice to have when you have already bought one (like i did) but when you look at it it's allot of things that i would have bought before the setup station...
Martin.S is offline
Old 07-05-2010, 05:10 PM
  #3424
A setup station is quite expensive though, maybe just using eyeball for now
I have more question guys, what is the use of making the car stiffer? like using alu chassis braces, and have you try AKA enduro for outdoor and slightly dusty track? how it feels?
Wilson Picaldy is offline
Old 07-05-2010, 06:11 PM
  #3425
Jammin57's Avatar
Trader Rating: 120 (100%+)
Anybody fitted a bulldog body on the mp9 yet????
Jammin57 is offline
Old 07-05-2010, 06:37 PM
  #3426
S Bowen's Avatar
Trader Rating: 57 (100%+)
Not yet but I have a RC8 bulldog getting painted right now to try. I'll let ya know when i get it back.
S Bowen is offline
Old 07-05-2010, 07:08 PM
  #3427
Yeah. The bulldog body will work on the MP9. Pay close attention when you cut it out though. The holes for the body mounts are not the same. The hole for the rear mount has to be moved toward the rear. Do not cut the rear top line of the body until you fit it to the buggy. The lines at the front and rear change but it doesn't take that much modification. Good luck.
Dcracing2 is offline
Old 07-05-2010, 07:28 PM
  #3428
Jammin57's Avatar
Which bulldog body did you use??? And do you have any pics
Jammin57 is offline
Old 07-05-2010, 08:44 PM
  #3429
Sorry about that! RC8 body in the J Concepts Punisher or the Pro line RC8 bulldog.
Old 07-05-2010, 09:58 PM
  #3430
Sorry guys the link below will show u the body, iPad junk won't copy and paste the right image code! .
Proline RC8 bulldog, yes the body holes are different rest of the lines are close, I have alsomfitted the punished rc8 body on my buggy no pictured yet tho, the punisher needs a little more work to make it work, be care cutting out fuel opening hole, and engine hole, engine hole needs to be more forward not as far backl pictures will b up later.
Andy
Last edited by 02maxima18; 07-05-2010 at 10:08 PM. Reason: Wrong pic code iPad junk
02maxima18 is offline
Old 07-05-2010, 10:07 PM
  #3431
http://i226.photobucket.com/download...a18/newmp9.jpg
Old 07-05-2010, 10:59 PM
  #3432
Is there any steering improvement after using bulldog body?
Old 07-06-2010, 06:23 PM
  #3433
Jammin57's Avatar
Thanks for posting a pic will probably be ordering one for mine
Jammin57 is offline
Old 07-06-2010, 08:06 PM
  #3434
To be honest maybe on the steering I don't see a difference tracks around here the pros average lap speed is 11-12mph. There is a difference in engine cooling, no lie My engines run about 10-15 degrees cooler average, my ninja used to run about 230-235 and with the new body 210-220, and when I switched fuels average 200 with the same power.
I think the body looks great, fits great, and increases performance, to bad they are roar illegal.
Andy
Old 07-07-2010, 02:43 PM
  #3435
i think the new tk2 body will do just about the same... or i hope at least.
According to our importers here in Sweden we will have the tk2 on the 13th of august. So i guess thats about when it gets available in europe.
I'm sure getting one!
Martin.S is offline
