Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-30-2010, 08:26 AM
  #3406
ON A MISSION's Avatar
Trader Rating: 34 (100%+)
Originally Posted by 808gx7r
50bucks saying he wont be at the top for long... however if he switched to Xray... he'd be there till he was 70 atleast
I doubt any Xray driver will be knocking off Tebo ,Cav ,Ryan M, Drake ,Truhe any time soon .........
ON A MISSION is offline
Old 06-30-2010, 12:46 PM
  #3407
SteveP's Avatar
Originally Posted by Beeker
I have a very lame, and dumb question.
How much narrower is the MP9 compared to the mp777 sp2 car?
Basically, will the MP9 body fit the 777 sp2 car with little, or no huge mods?
Thanks in advance
The overall width of the car is the same, but as it relates to your question, it's more narrow from one side of the chassis to the other. I'm not sure by how much, but perhaps I can measure it. If you want a different body, I'm sure there are some options out there that will work. Perhaps a Pro-Line or JConcepts body for a Jammin, O'Donnell or some of the HoBao and HongNor cars would fit as they're wider like the 777.
SteveP is offline
Old 06-30-2010, 02:02 PM
  #3408
Thank you for the response! I was hoping the MP9 would fit as it has a overall lower style roof and all compared to the proline and jconcepts bodies for the 777.
If there is anyway you could measure for me I would highly appreciate it!
Beeker is offline
  #3409
Seeing as I've got a 777 sp2 and a MP9 I've just tried it and the only thing stopping the MP9 body going on was the back section catching against the shock tower, apart from that it seemed to fit ok.
Neil777 is offline
Old 06-30-2010, 02:10 PM
  #3410
Thank you kind sir! I owe you a beer!
Beeker is offline
Old 06-30-2010, 06:02 PM
  #3411
hi guys, which tires do you think better for a loamy, dusty, and some surfaces are pavement covered with dust? My options are between soft I-Beam and soft city blocks
thanks guys.
Wilson Picaldy is offline
Old 07-02-2010, 04:26 PM
  #3412
pitpop's Avatar
CONGRATS TEAM KYOSHO AND TEBO ON DUAL NATIONAL TITLES... The MP9 is on a roll with no end in sight. It's only going to get better between now and Pattaya.
Next stop, IFMAR Worlds...
pitpop is offline
Old 07-02-2010, 05:00 PM
  #3413
KWT-NITRO's Avatar
thanks guys.
Soft I-Beam for me
KWT-NITRO is offline
Old 07-02-2010, 09:46 PM
  #3414
Originally Posted by KWT-NITRO
Soft I-Beam for me
Thank you! Tried soft I-Beam and it was really impressive, better than the soft City Block. The rear end still a bit loose though. Thinking of moving the camber link to number 3 hole on the shock tower (currently on number 8 hole and down left hole on the alu rear hub) and thicken up the front oil to #400 (currently #350 all around). What do you think can I expect from these change? Thanks!
Old 07-03-2010, 02:46 PM
  #3415
pitpop's Avatar
I like your idea on the #3 camber link hole, that's where we end up if you want more rear traction. Also you can lower the rear oil to settle it down or lower the middle for more front wheel spin. Raising the front oil will help too, but mainly it will jump better.
pitpop is offline
Old 07-03-2010, 04:02 PM
  #3416
Thanks a lot pitpop, I'll try it today
Old 07-03-2010, 04:05 PM
  #3417
808gx7r's Avatar
now that you said that wouldnt it be funny if josh wheeler won ifmars
808gx7r is offline
Old 07-03-2010, 04:27 PM
  #3418
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Tebo's ROAR Nationals set up is posted now:
http://www.kyoshoamerica.com/downloa...2010-07-02.pdf
johnnyboy is offline
Old 07-03-2010, 07:17 PM
  #3419
Trader Rating: 16 (100%+)
Josh wheeler races at my local track along with Matt Gosch, Wheeler would be one of the top 10 at every event, but he doesn't practice more than maybe one or 2 days every week. I would think pro's like Maifield, Tebo, and Drake run run very often
Zach Phillips is offline
Old 07-05-2010, 06:15 AM
  #3420
guys, how long is the turn buckle to get 0.5* and 1* toe out? don't have any toe gauge thanks
