Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-21-2010, 02:22 AM
  #3376
Originally Posted by cflopes
It is the fourth time this happens. My friends also have the same problem. Any solution?
this cars are not build for a demolition Derbies....My MP9 tki is on is second season of racing, I replaced the bulkheads to the c, and two front arms due to the pipe/wall being stronger than the car....the rest is just regular maintenance.
RAlmeida is offline
Old 06-21-2010, 06:26 AM
  #3377
I have a TKI for sale here for $350.: http://www.rctech.net/forum/r-c-item...ervo-more.html
Car is tight and upgraded, with a ton of spares. Tracking my 1:1 is taking up the play time. The TKI is awesome, wish I had the time...
phm14 is offline
Old 06-21-2010, 10:39 AM
  #3378
Frank L's Avatar
Trader Rating: 148 (100%+)
Hey guys check this out all Kyosho products in stock at carolinas rc are 65% off!!
http://www.carolinasrc.com/webstore/...=20&viewType=2
Frank L is offline
Old 06-21-2010, 01:07 PM
  #3379
captain america's Avatar
Looks like they're just liquidating the older MP777 stock.
captain america is offline
Old 06-21-2010, 02:57 PM
  #3380
merdith6's Avatar
Default Well.
Originally Posted by Matthijs
yes, stop hitting the pipe! I only broke my front arms after a very hard hit or crash. It's not something to worry about.. I even broke frontarms with my mp7.5 or mp777. Part of racing.
I raced a 7.5 and a 777 for years and never broke an a arm, but to be fair I don't own an mp9, I love the new body and improvements, Kinda wish I still raced Kyosho. I did replace the front a arms due to sagging from landing off jumps, but most every buggy does that, the front arms are probably the most abused part of any car.....Keep a few spares on hand....
merdith6 is offline
Old 06-21-2010, 08:09 PM
  #3381
any one knwo where i can buy a set of aluminium front hub carriers from. i think i would prefer to use the aluminium ones rather than the plastic ones.
deeps73 is offline
Old 06-22-2010, 06:39 AM
  #3382
Trader Rating: 25 (100%+)
Try here
http://translate.googleusercontent.c...36ICH3kyxPcXWA
smelly62 is offline
Old 06-22-2010, 11:03 AM
  #3383
Key
Key's Avatar
new car from Kanai at the masters in Paris, thanks to RCMag.
more on: http://rcmag.com/modules.php?name=Fo...=431007#431007
Are the shock oil labels home made or is it something available through kyosho? I hate using a marker on pretty parts
Key is offline
Old 06-23-2010, 05:03 AM
  #3384
Ha Ha I was thinking the same thing.
smelly62 is offline
Old 06-23-2010, 05:15 AM
  #3385
Both my Son and I raced every model 7.5 and 777 and never broke a front arm but since we have MP9 over 15 broken arms between the both of us.
If you make sure the upper arm is not sloppy or use the King Headz upper arm you will break less lower arms (prevents the lower arm twisting on hard impact).
We modify the plastic upgraded upper arms by drilling the inner pivot hole to 15/64" and press the delrin bush from the King Headz arms in. They last forever this way and much less lower arm breakages.
The upper arm on the MP9 is of very poor design and should be more wider at the inner pivot like the old 777's.
smelly62 is offline
Old 06-23-2010, 05:30 AM
  #3386
osis's Avatar
Hay smelly...just get a mugen and you wont have to worry about broken arms.......Flame away ppls
osis is offline
Old 06-23-2010, 05:36 AM
  #3387
Yeah thats the ONLY thing you don't have to worry about with a mugen.
I reckon it's all that paint and stickers that holds your car together. LOL
Get the ute serviced ok?
smelly62 is offline
Old 06-23-2010, 05:51 AM
  #3388
osis's Avatar
Yep Steve,all good mate.Stuck some mugen stickers on it and it go's twice as fast now
osis is offline
Old 06-24-2010, 02:42 PM
  #3389
Ya I hear ya when I switched from my mbx6 to the mp9 I broke a lot of arms all the time, but 1. I used the older style arms not the hard updated ones. 2. The uppers weren't spaced correctly. 3. I learned how to drive the mp9 the mugen will take a beatin, kyosho too but I think of it as more of a agile precise buggy opposite of the mugen,mugen will also need hours upon hours of maintaince for the buggy to feel consistent ( for me at least)
I love my mp9 I haven't broken in arm in 7-8 races, broke on rear hub which is an original I had on the car when I replaced all the plastics when I got it 12-13 races ago. Buggy is just so good can't wait for the TKI2 to come out!
02maxima18 is offline
Old 06-24-2010, 05:18 PM
  #3390
Default Arms
I also had an MP 777. Never broke anything, but my PM9 has already broken several parts
cflopes is offline
