Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-15-2010, 11:22 AM
  #3361
Hi Guys,
Loving the new TKI2 kit.
Not sure on the Bodyshell just yet????
Where can i find the information on the option parts.
I'm looking at buying the parts to upgrade my Kit already.
This is what i have so far please feel free to suggest any other parts
Rear Alloy Hub
93MM rear drive shafts
Alum Wing Mounts
Alum front upper holder
Alum radio posts
Long King Pin Set
Rear Torq Rod Bushings
Thats on my to order list so far
carlin is offline
Old 06-15-2010, 12:01 PM
  #3362
Key
Key's Avatar
@Matthijs and @jlbanta:
Thanks guys.
Key is offline
Old 06-15-2010, 06:01 PM
  #3363
pitpop's Avatar
Originally Posted by deeps73
just thought i would share this with you saw this on Tebo's car when he was over here in aus a couple of months ago. Notice how the battery is mounted at the front of the car next to the steering servo. This was also done on his truggy. pics below. What do you think the reason for this could be? is it worth doing it maybe pitpop can answer this?
Jared moved the battery to move the weight a little. Seems like a sano set-up since he direct wires his battery. It gets a little sketchy if it's damp or wet outside, but in the dry it should be fine.
pitpop is offline
Old 06-15-2010, 06:04 PM
  #3364
pitpop's Avatar
Originally Posted by Alan D.
PK, what were guys running with the long rear shocks on the mp9? Don't have the mediums.
Hi Alan. We have always run the long green springs on the long & the medium shock bodies. We go to the shorter springs for high bite conditions.
pitpop is offline
Old 06-17-2010, 07:41 AM
  #3365
Hello everyone......
Hi Matthijs - i saw your earlier post on the new MP9 parts and i pressume you got those great staffs from Japan directly. Mind to share which website / Japan hobby shop you normally gets your MP9 parts from.....
Thanks!
Regards,
David
David Lim is offline
Old 06-17-2010, 09:30 AM
  #3366
deeje929's Avatar
I was wondering if the TKI 2 comes with 93mm unis.
Hi PK, This is Coach Townsend
deeje929 is offline
Old 06-17-2010, 11:44 AM
  #3367
Matthijs's Avatar
Thanks!
Regards,
David
Hi, most parts I get directly from Kyosho Germany who have a great direct line with Kyosho Japan and some smart people who understand our needs ;-)
The new hardened flange balls I ordered at RCchamp in Japan because they were not shipped to Europe on time. http://www.rc-champ.co.jp/
Matthijs is offline
Old 06-17-2010, 12:23 PM
  #3368
deeje929's Avatar
How can i get on of those polo shirts and jackets from Germany
deeje929 is offline
Old 06-18-2010, 07:33 AM
  #3369
Hi Matthijs - Thanks for the information......
Cheers!
Regards,
David
Old 06-18-2010, 11:38 AM
  #3370
clxforever's Avatar
Where can you Buy the new Parts?
Please have List with code the new Parts TK2 for upgrade my TKI?
Thanks and sorry for my english.
clxforever is offline
Old 06-18-2010, 01:43 PM
  #3371
Matthijs's Avatar
new car from Kanai at the masters in Paris, thanks to RCMag.
more on: http://rcmag.com/modules.php?name=Fo...=431007#431007
Matthijs is offline
Old 06-18-2010, 10:41 PM
  #3372
clxforever's Avatar
Please?
Old 06-18-2010, 11:56 PM
  #3373
Matthijs's Avatar
Please?
most new parts for the TK2 are not yet available (shocks, filter, body). For an overview look at: http://www.kyosho.com/eng/fun/specia...al_data02.html
Matthijs is offline
Old 06-20-2010, 04:32 PM
  #3374
Default Problems Arms IF427
It is the fourth time this happens. My friends also have the same problem. Any solution?
cflopes is offline
Old 06-20-2010, 10:59 PM
  #3375
Matthijs's Avatar
yes, stop hitting the pipe! I only broke my front arms after a very hard hit or crash. It's not something to worry about.. I even broke frontarms with my mp7.5 or mp777. Part of racing.
Matthijs is offline
