Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 05-25-2010, 08:21 AM
  #3301
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
im trying to find the part number for shock shafts on the rear medium shocks? i have the tki fronts and rears but not the new mediums shock shafts could someone help me out please i need to get some orderd
bigBoyBigToy is offline
Old 05-25-2010, 09:39 AM
  #3302
Matthijs's Avatar
IFW141-02, same as the ST-RR front shocks
Matthijs is offline
Old 05-26-2010, 01:39 AM
  #3303
mp9er's Avatar
mp9er is offline
Old 05-26-2010, 05:45 AM
  #3304
Key
Key's Avatar
@Matthijs: Are you using Orion Vortex servos for steering on your MP9e? I'm looking into getting one but don't know which one is best suited for my MP9e. They've got quite a line-up:
VDS-1007
VDS-2015
VDS-1409
-key
Key is offline
Old 05-26-2010, 06:46 AM
  #3305
Tor
Key, I'm a team driver for Kyosho and Joe Pillars sent me the 2015's, which I have been running in my Mp9 for 8 months. I really like them.
Tor is offline
Old 05-26-2010, 07:16 AM
  #3306
johnnyboy's Avatar
Trader Rating: 28 (97%+)
VDS-1007
VDS-2015
VDS-1409
-key
I have used them all.
VDS-1007: Super Fast but a little light on torque for 8th scale steering. Wouldn't use for throttle/brakes.
VDS-1409: Fast and strong. Great steering servo and decent for throttle/brakes
VDS-2015: Crazy torque. Awesome for throttle/brakes but I found it a little slow for steering.
I am currently using the VDS-1409 for steering and VDS-2015 for throttle/brakes in my Nitro car
In my MP9e I am using the VDS-1409 for steering and found it to be the best of the three for that.
johnnyboy is offline
Old 05-26-2010, 12:33 PM
  #3307
Matthijs's Avatar
VDS-1007
VDS-2015
VDS-1409
-key
neither... I'm using Hitec 7955 in all my car's. In nitro on 7.4 lipo direct with kopropo receiver & in the mp9e on 6v. On 6v it's fast enough and very strong. I mostly drive on astroturf with lots of grip. I can use all the steering & holding power I can get, hence the Hitec on lipo in the Nitro car. When I prepared my MP9e I choose to use Hitec again for steering to I can change servo's if one fails on a race day without changing endpoints, centerpoints and horns. I do like the Orions, but the hitec never seem to fail or give me any reason to change ;-)
Matthijs is offline
Old 05-26-2010, 06:30 PM
  #3308
Key
Key's Avatar
Tor, Johnnyboy, Matthijs >> thank you for the valuable info! Hitec makes sense if that's all you're using but I'm gonna go for the Orion VDS-1409 for steering that JB mentioned.
Key is offline
Old 05-28-2010, 11:28 AM
  #3309
pitpop's Avatar
Default set-up sheet
Here is a set-up sheet for the SE, it pretty much works for all the MP9 buggies. It's not editable, but it's the current sheet anyway. If I can dig up an editable sheet I will post it. I think there is one available maybe on the Japan site.
http://www.kyoshoamerica.com/downloa...lank_setup.pdf
pitpop is offline
Old 05-30-2010, 07:41 AM
  #3310
hey guys
does any one know when the new MP9 TKI 2 will be out for sale.
deeps73 is offline
Old 05-30-2010, 08:40 AM
  #3311
Originally Posted by deeps73
hey guys
And also the TKI 2 body?
Neil777 is offline
Old 05-31-2010, 09:45 AM
  #3312
hey guys
Joe Pillars said the TKI 2.0 kits are not expected for another 2 months or so!
Has anybody found more details on the new kit? NeoBuggy listed a few things...but the info was limited.
jlbanta is offline
Old 05-31-2010, 12:12 PM
  #3313
Default MPTKI2
The release date of the the new kit should be sometime in July....but that is in Japan, so I would expect it to hit the US in August....
The new parts:
New body
New Air Filter
Captured Tie Rod ends
Aluminum Rear hubs(looks like plus 2mm style)
Aluminum Rear Arm Holder
Medium Rear Tower
Threaded Shock Bodies
Aluminum Wing Mount Braces
Aluminum Radio Tray Posts
All updated Plastic
New Dish Wheels
Updated Tank Pull
Walid
Pics do not show it but there are updated rear outer hinge pins(hardened version) that are out, but not sure if it going to come on TKI2 car.
There is a prebuilt car that is also going to be released.....
walidelagamy is offline
Old 05-31-2010, 04:30 PM
  #3314
Key
Key's Avatar
97% of the parts listed are available as we speak.
The only items not available except for the shock bodies are nitro specific: threaded bodies, body (i like the first gen.), updated tank pull and air filter.
Key is offline
Old 06-01-2010, 05:28 AM
  #3315
I dont understand why they didnt just put out a service pack or update pack for the TKI.. I still think a new truggy would have been the way to go.
The Chad Man is offline
