Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 05-13-2010, 01:18 PM
  #3271
I see they changed the wing, and that body looks sweet. Kinda like a bulldog..
Whats going on with that servo saver?
The Chad Man is offline
Old 05-13-2010, 01:19 PM
  #3272
Matthijs's Avatar
new body is a Tosa Inu (thats a kind of a japanese bulldog)
could someone please explain the advantage of threaded shock bodies? I really like the clips! Accurate and spot on... but that's just me...
Matthijs is offline
Old 05-13-2010, 01:26 PM
  #3273
I'm not a fan of threaded shocks on offroad cars.. I like he ^^^^ said they are quick and easy....
Old 05-13-2010, 01:53 PM
  #3274
Trader Rating: 16 (100%+)
I hope those "mirrors" are not on the production car
Zach Phillips is offline
Old 05-13-2010, 03:19 PM
  #3275
Trader Rating: 47 (100%+)
wheres the new truggy
transplantlife is offline
Old 05-13-2010, 04:58 PM
  #3276
R/C Tech Elite Member
Trevor Williams's Avatar
Trader Rating: 207 (100%+)
for real
Trevor Williams is offline
Old 05-13-2010, 05:25 PM
  #3277
Jammin57's Avatar
Trader Rating: 120 (100%+)
+1 they need a new truggy instead of making small changes on the same buggy there isn't alot of people still running the st-rr if they had a new truggy I would run it instead of my mugen
Jammin57 is offline
Old 05-13-2010, 05:54 PM
  #3278
Trader Rating: 28 (100%+)
+1
bphil49 is offline
Old 05-15-2010, 11:22 AM
  #3279
Key
Key's Avatar
+2
Key is offline
Old 05-15-2010, 03:14 PM
  #3280
t8rtot's Avatar
Trader Rating: 14 (94%+)
Its funny... ppl complain when a company releases updated kits too fast.. so let's say they release a st-rr2 intead of the 2 to get it updated with the current mp9.. then everybody complains that the team drivers have updated mp9 kits then the st-rr2 is outdated again.. so then nobody has the most updated kit.. (more complaing..) then the mp9 tki2 comes out then a st-rr3 has to be released...
So I think it would be best to have the most updated buggy (your flagship) then have the truggy (which isn't run as largely in some other countries) released. BAM! hope that makes sense. Not ment to be personal but think logically.the st-rr is no less capable then the newer mugens or losi's etc.. actually if I remember right the STRR wasnt based off of the mp777 (st-r) it was a totally new design (may be wrong) then came the mp9.. so actually kyosho was ahead of the curve and everybody else is just catching up now..
Again nothing personal but there is a method to there madness we just have to be patient (sux)
t8rtot is offline
Old 05-15-2010, 10:19 PM
  #3281
KWT-NITRO's Avatar
what's wrong with the ST-RR???
KWT-NITRO is offline
Old 05-16-2010, 12:07 AM
  #3282
Jammin57's Avatar
t8rtot the st-r/st-rr was based off the mp777 buggy, the st-rr was out way before the mp9 there has been 3 mp9 kits released in 2 years and basically the only things that have been changed is shorter rear shocks and shock tower, threaded shocks and new body, does that justify having 3 different kits?? the st-rr is still very capable of doing just as good if not better than the new trucks coming out but the biggest flaw with the st-rr is the rear ring and pinion gear and the flexible bulkhead that has caused ALOT of kyosho fans (myself included) to switch to a different brand truggy but instead of kyosho coming out with a harder bulkhead or straight cut gears to fix this problem they keep working on a buggy that really does not need any change and considering truggy is growing and growing (itleast in the US) kyosho should really be working on a better truggy instead of coming out with a new mp9 that basically all it has new is threaded shocks and new body. kyosho is favorite brand so i am not bad mouthing them but if they come out with a new truck they would get ALOT of people switching back to kyosho
Jammin57 is offline
Old 05-16-2010, 06:48 AM
  #3283
One of the photos shows the steering arm where it links to the knuckle, the text underneath says "New" followed by some Japanese text, what have they changed?
Neil777 is offline
Old 05-16-2010, 12:41 PM
  #3284
Does anyone know if the Ascendancy 13t clutch bell fits the mp9?
Old 05-16-2010, 04:10 PM
  #3285
Any ideas as whether the RC8 buggy body will fit an MP9, I'm really keen on the new punisher body, a close fit will be fine, don't mind doin a bit of gentle persuasion.
B.C.Ninja is offline
