Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 04-30-2010, 11:52 PM
  #3256
mp9er's Avatar
Post
its not another updated mp9 its a track at kyo america
least i dont have to save my pennys now
mp9er is offline
Old 05-05-2010, 02:12 AM
  #3257
Originally Posted by The Chad Man
One thing I have noticed about the car this past weekend was that the brakes were getting choppy at the end. I got home and did the tear down and noticed that the outdrives on the center diff were rubbing on the bottom of the brake pads.. I took a close look at the pad mounting posts and found they were not worn and looked straight. (not bent down). Next place I looked was were the diff bearings ride in the center mount and those looked and felt good...everything looks good but somewere I lost some clearance from the outdrive to the bottom of the pads..... I took my trust dremel with a sand pad and took some material off so that metal is flush with the pad meterial itself on the bottom side.. I didnt loose any breaking surface but gained alot of outdrive clearance.... Has anyone else came accross this?
yes, i have had a similar problem, did the same thing as you, just took off some material with the dremel, i noticed it before i even got the car outside.
and btw, i you put a front/rear diff output on the center diff the brakedisks wont fit at all so...
/M
Martin.S is offline
Old 05-05-2010, 10:24 PM
  #3258
Hi
what do you think of my completed new MP9 TKI edition with a new OS Speed hara edition?
Attached Thumbnails Inferno MP9 thread-photo-2.jpg   Inferno MP9 thread-mp9.jpg
deepal is offline
Old 05-05-2010, 10:25 PM
  #3259
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 101 (100%+)
Need a brighter body! I couldnt even drive that $hit at night!
BSchorr is offline
Old 05-05-2010, 10:30 PM
  #3260
we dont drive at night here in aus.
deepal is offline
Old 05-05-2010, 10:45 PM
  #3261
Matthijs's Avatar
Originally Posted by deepal
Hi
like it! run it with black mp9 rimms!
Matthijs is offline
Old 05-05-2010, 11:32 PM
  #3262
Thanks mate yep got the black rims ready to be mounted on the car
deepal is offline
Old 05-09-2010, 01:22 AM
  #3263
I'm trying to unscrew the ball ends on my rear shocks to get more droop but they're too tight, I bought some so called shock shaft pliers but they're pretty useless.
Has anybody got any tips.
Neil777 is offline
Old 05-09-2010, 02:39 AM
  #3264
Ignore me, the pliers work fine, I was using the wrong size slot.
One thing I've noticed though is that unscrewing by 3 turns as recommended a few pages back only gives me 121mm, to get 123mm I have to go to 6 turns.
Neil777 is offline
Old 05-09-2010, 05:22 AM
  #3265
I dont think I would dare go 6 turns out on the shock bottoms.. Seems like 3 turns out is about 1/3 of the way out already. I think I tasted that sour milk before........ I tried going to far past the safe zone with my 777 back in the day and ended up trashing a shock shaft since it was cutting a trench in the track...
The Chad Man is offline
Old 05-10-2010, 12:13 AM
  #3266
mp9er's Avatar
Post
yes thats right its a litle past 3 turns but you will be okay ive been running 123mm for a while and no probs if youve got a spare shock handy fully screwed in you can unscrew the other to 123mm and size them up you will see they still screw in deep enough
i think its only 4 maybe 5 not six are you measuring center top cap center bottom eyelet
mp9er is offline
Old 05-10-2010, 01:47 AM
  #3267
Yes I was measuring from the centres.
Neil777 is offline
Old 05-10-2010, 01:53 AM
  #3268
I just had another look and don't know how I managed to miss it before but the bottom balls were pointing slightly upwards as I was looking at them.
Neil777 is offline
Old 05-13-2010, 12:58 PM
  #3269
captain america's Avatar
The new TKI 2 buggy breaks cover...
http://www.buggy-sport.info/index.ph...egory&catid=44
At a glance, I see threaded shock bodies and a resculpted bodyshell around the engine.
captain america is offline
Old 05-13-2010, 01:02 PM
  #3270
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Thank God for threaded shocks.
johnnyboy is offline
