Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-11-2010, 12:10 PM
  #3001
aaron joy's Avatar
Trader Rating: 17 (95%+)
Kyosho "E" bodies are now available from Kyosho USA, I believe that is where my buddy bought his from. Im painting it in the next couple of days, I will post a pic of it mounted. Does anyone have a good starting setup a MP9 with e-conversion?
Thanks,
Aaron
aaron joy is offline
Old 02-11-2010, 12:40 PM
  #3002
Jammin57's Avatar
Trader Rating: 120 (100%+)
Originally Posted by AndyMoore
Lower Kv = more turns = more torque = less top end and less overall power?
lower kv motor is less turns
you run higher voltage on a lower kv motor to get the same torque and speed, running a lower kv motor and higher voltage is just more efficient and puts less strain on the battery most people gear a buggy/truggy to run about 35-40mph depending on the track all the different kv motors will run the same speed it just depends on if you want to run 4s,5s,6s its all personal preference
Jammin57 is offline
Old 02-11-2010, 04:24 PM
  #3003
AndyMoore's Avatar
Trader Rating: 64 (100%+)
I think its less turns more Kv? Good information about the voltage though...I'll take that into consideration when I order my motor.
LRP 10.5T - Specific RPM/V (KV): 3,600
LRP 5.5T - Specific RPM/V (KV): 6,300
AndyMoore is offline
Old 02-12-2010, 04:24 PM
  #3004
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Originally Posted by Matthijs
does that body fit without modifications? I've got the Jconcepts for the MP9 and it is too low for the lipo's.
thanks for the info!
Just did some quick research. Put a buddies JC RC8e body over a JC MP9 body and they line up mint!
Attached Thumbnails Inferno MP9 thread-dsc07531.jpg   Inferno MP9 thread-dsc07532.jpg   Inferno MP9 thread-dsc07533.jpg
johnnyboy is offline
Old 02-12-2010, 10:37 PM
  #3005
rcmadman316's Avatar
Originally Posted by johnnyboy
Really? No mods? Can you post a pic of it? That body looks killer and would be sweet if it fits the MP9 well.
Sorry i haven't checked this thread I'll post pictures of mine tomorrow.But it fits with no mods looks sweet 2..I hate to say it but kyosho bodies are way to thin they don't live long enough for me.
rcmadman316 is offline
Old 02-13-2010, 12:21 AM
  #3006
foampervert's Avatar
Default mp9E bodyshell
Hiya folks,
does the Mp9E bodyshell come with pre-cut holes (the 2 holes on the side pods and holes behind the canopy)
I'm wondering if I can use the MP9E bodyshell on a regular MP9? I wouldn't mind a bit more cooling air over the pipe as I live in sunny, hot Singapore.
-Alexander
foampervert is offline
Old 02-13-2010, 10:54 AM
  #3007
Jammin57's Avatar
andy the way 1/8 scale motors are figured is
2200kv x14.8volts=32560rpm's
1700kv x 14.8volts=25160rpm's
the lower kv motor is less rpm's on the same voltage thats why the lower kv motor you run the more voltage you use to get the same speed/rpm's
Jammin57 is offline
Old 02-13-2010, 05:50 PM
  #3008
Originally Posted by foampervert
Hiya folks,
-Alexander
No, it's not pre-cut.
You can use it with the regular MP9 if you adjust the airfilter holder and fix it so it can't bend down. David is making one body now and i think i have done a good solution with the air filter holder.
I will put up some pictures when we have tested it.
PiRo is offline
Old 02-14-2010, 07:12 AM
  #3009
Default Thanks for the info!
Hiya Piro,
Thanks for the info, I really do appreciate your sharing David's setups.
I wish you and David all the best this year, especially at the Ifmar Worlds!
Shalom and God Bless!
-Alexander
Old 02-15-2010, 05:26 PM
  #3010
pitpop's Avatar
Hi Pierre. How's everything? ... e body on the gas car?
pitpop is offline
Old 02-16-2010, 12:32 AM
  #3011
Matthijs's Avatar
Hello Mr. King, any word on the MP10 ready in time for the worlds?
Did Cody do some more driving with the MP9e? There isn't much info to find on the Orion Vortex setup, can you share some?
Last question, can you explain me a little bit on the Peak racing thing? Is this brand alive again because Orion is now distributed by Horizon and Kyosho wanted to have their 'own' line on lipo's and stuff? Peak isn't really active in Europe, hence my questions. thanks for your time!
Matthijs is offline
Old 02-16-2010, 08:11 AM
  #3012
MP10? please tell us about this!
cheezy91 is offline
Old 02-16-2010, 12:43 PM
  #3013
Matthijs's Avatar
please notice the big green grin
but then again.... it's the year for the worlds...
Matthijs is offline
Old 02-16-2010, 01:34 PM
  #3014
just curious,just got my mp9 and would hate to see a new car come out now
cheezy91 is offline
Old 02-16-2010, 01:37 PM
  #3015
Dyno-Dylan's Avatar
Trader Rating: 36 (100%+)
Im not on the team, However they have been using the same truggy for a while now and it's still competitive. I see no problems with my MP9 and doubt there will be a new one.
Dyno-Dylan is offline
