Inferno MP9 thread
#2851
sonic,
i have both cars and the mp9 body does not fit well on the 777. The original kyosho body fits better than the j concepts body, but you are wasting your time and money with the kyosho body. It is just to thin and does not last. I suppose with some major trimming it might work but it will never fit right. You might be better off just to order a 777 body on line somewhere.
Also, if they were interchangeable Kyosho would not make two separate bodies for the electric infernos MP777e/7.5VE's and MP9e:
MP9e
http://www.kyosho.fr/index.php?optio...res&Itemid=111
VE (aka inferno mp 7.5 & 777)
http://www.kyoshoamerica.com/cars/in...part_num=30875
#2853
100mm, with the shock in the middle hole on the tower
#2855
Here is Ryan Eckerts MP9, running W.E.D. paint,
! As you can see from the pic he is obviously saving the tires for later in the A main run at the Clash race, where he finished 4th!
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com
#2857
Hey paul i also race with nigel and were trying to get a few more guys onboard now that the se is out and the price is right.. So the rear toe block the toe is determinded by the bushing correct? I ran the stock settings last year what does the equal to? I also ran the stock springs last year
any suggestion on shock springs?
#2858
pk ic you have cody eletric car done i am in the middle of working on mine!
i was just wondering what batt are you runing?
and what other parts should i order for the car?
#2859
#2860
What motor and speed control are you using with that?
#2861
-key
#2862
would you guys by chance be happing to bring the car with you to crcrc. i really like to look at it i know it the car i should be run but can i affored to run it is the real problem lol.
i was wondering what springs are the same as the stock black ones i was told they dont have the coating and there scrating the body really bad.
also what gearing would you be runing and what base set up should i start with
i know i gone get the car but i am still going back and 4th about eletric or nitro lol
#2863
what bodies is everyone using? last year i used Jconcepts!!
what body do all of you like and use?
#2864
I don't run the MP9, but I have painted A LOT of the bodies for them. Most I paint seem to prefer the JConcepts bodies over the Kyosho brand. Since the JC bodies are quite a bit thicker and last easily twice as long.
I have also painted some thicker Kysoho bodies, but I don't think they are readily available yet.
This is a stock MP9 body I recently painted for Team Driver Ryan Eckert.
This is a recent JConcepts body
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com
