Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-12-2009, 05:53 PM
  #2836
pitpop's Avatar
Hey Pierre, beside using the wrong hole on the rear hubs, what antisquat are you using?
bigboy, the MP9 chassis is very good. It has the longest wear of any we've seen, so if you can get the K item, I would say it's a good idea. If you don't have the alum rear toe block, that thing is golden... - PK
pitpop is offline
Old 12-12-2009, 06:43 PM
  #2837
didrace's Avatar
I think paul is picking on someone..
We wanna see a competition of Cody and David one Day!!And their mechanics at pit stops.
I dont want to bring fire guys i am just teasing!!! dont get me wrong please!!
didrace is offline
Old 12-13-2009, 01:44 AM
  #2838
Hi PK,
I missed that one. We are using "Roll Center L" and 2 degree
PiRo is offline
Old 12-13-2009, 09:28 AM
  #2839
Trader Rating: 19 (100%+)
Default Thanks
Originally Posted by PiRo
This is Davids normal setup that he always start with.
Thanks for the help!!
Chartos is offline
Old 12-13-2009, 04:42 PM
  #2840
pitpop's Avatar
Cody and David will have a lot of races together. We already had one at France Masters. David is very fast and mature beyond his age for sure.
pitpop is offline
Old 12-14-2009, 07:13 AM
  #2841
Sonic Gear's Avatar
Hi Guys,
I own a 777Sp2 and been thinking if the MP9 body does fit into 777Sp2 ?
I know sure need some triming but overall, does it fit ?
thanks a million.
Sonic Gear is offline
Old 12-14-2009, 08:23 AM
  #2842
Gizmatron's Avatar
Originally Posted by Sonic Gear
Hi Guys,
thanks a million.
I very much doubt it.the mp9 is considerably lower profile..typically for the first time in weeks I don't have any mp9 shells awaiting painting or i'd try one on my 777 for you.Why do you want to fit an mp9 body to an sp2?
Gizmatron is offline
Old 12-14-2009, 12:04 PM
  #2843
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Help out a 10th scale electric guy!
New to 8th scale. What Kyosho option parts should I be getting for an MP9SE?
johnnyboy is offline
Old 12-14-2009, 01:14 PM
  #2844
pitpop's Avatar
Nothing really needed, but I would suggest IFW407, it lasts forever.
http://www.amainhobbies.com/product_...r-Toe-In-Plate
pitpop is offline
Old 12-14-2009, 05:21 PM
  #2845
Sonic Gear's Avatar
our local store dont carry any 777 bodyshell anymore except MP9.
so was trying to see if does fit and of course, the MP9 shell does look cool
please. please , try and let us know if does fit
thanks a million
Old 12-14-2009, 06:14 PM
  #2846
sonic,
i have both cars and the mp9 body does not fit well on the 777. The original kyosho body fits better than the j concepts body, but you are wasting your time and money with the kyosho body. It is just to thin and does not last. I suppose with some major trimming it might work but it will never fit right. You might be better off just to order a 777 body on line somewhere.
willienaylor is offline
Old 12-14-2009, 11:41 PM
  #2847
Gizmatron's Avatar
Originally Posted by willienaylor
sonic,
couldn't agree more..the oem body is ugly too..I have 3 or 4 proline crowdpleazer2 bodies for mine and they are simply the best..nice fit and finish and top quality..get one online or ebay somewhere..
Old 12-15-2009, 10:32 AM
  #2848
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
Hey paul i also race with nigel and were trying to get a few more guys onboard now that the se is out and the price is right.. So the rear toe block the toe is determinded by the bushing correct? I ran the stock settings last year what does the equal to? I also ran the stock springs last year
any suggestion on shock springs?
bigBoyBigToy is offline
Old 12-15-2009, 04:19 PM
  #2849
energydrink's Avatar
The amount of toe you run is molded into the bushing. The block says nothing about the bushing other than the KindHeadz one which is a +.5* block.
energydrink is offline
Old 12-16-2009, 12:11 PM
  #2850
trf415msx's Avatar
Trader Rating: 24 (100%+)
MP9 TKI back in stock ay AmianHobbies very good price $769.99 and you can use copoun to get dicount for $50.00...CALHPY950 Happy x-mas to you all
trf415msx is offline
