Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-08-2009, 07:53 AM
  #2821
Jammin57's Avatar
Trader Rating: 120 (100%+)
Originally Posted by Gizmatron
the original poster was yes and I posted the exact same reply as you but I think if you scroll up a couple of lines you'll see a request for lipo availability for a nomadio react which last time I looked was a RADIO!!!
The guy asked about the rx not the radio
the first thing you talked about was running a lipo in a radio he didn't ask about a radio just the rx
and I didn't mention anything about a nomadio radio
Jammin57 is offline
Old 12-08-2009, 08:33 AM
  #2822
Matthijs's Avatar
And now it's time for something else besides the electronics (skip that discussion, search in the Electronics thread and you will see you'll need a KoPropo transmitter/receiver, hitec 7955/7950/7940 and lipo)
I received my new rear alu hubs today from Japan, very nice and blingbling!
I need some testing on the upper mounting holes for the upperarm. In theory it will give you more steering I suppose?
Matthijs is offline
Old 12-08-2009, 11:08 AM
  #2823
Gizmatron's Avatar
jesus I wish I hadn't replied..I was replying to post 2809 by didrace about lipo availability for a nomadio react..it was all off topic anyway..sorry for any misunderstanding.
back on topic.nice alloy rear hubs...the lower holes look larger ..are they supplied with plastic inserts or is it just the photo making them look bigger? I love the plastic inserts kyosho fit between the bearings and steering knuckles at the front..just seems to give a better bearing fit and of course much cheaper to replace than the whole hub..do these rear hubs have the same blue inserts?
The 4 upper mounting holes look like they are 2 above and 2 below the original plastic holes which means you can change the upper arm angle and thus the roll center from the outside as well as the inner mount on the shock tower..without looking I think there are 4 holes for the inner mounting so this setup gives you the option of 8 upper arm angles instead of 4 with each additional angle being 1/2 way between the standard ones plus an extra 1/2 at each end..I think that makes sense????
Roll center is more about weight transfer than steering directly but in conjunction with other settings might certainly give you more or less steering..
Gizmatron is offline
Old 12-08-2009, 11:19 AM
  #2824
Key
Key's Avatar
Nice! How much were they including shipping from Japan?
Key is offline
Old 12-08-2009, 12:41 PM
  #2825
Matthijs's Avatar
They are sold for 5.775 yen in Japan, I got them a bit cheaper at Champ RC.
The hubs are not supplied with inserts, don't need them. the lower mounting holes (pin) are the same size, and so are the bearings. You don't need the nice plastic inserts for the bearings, but they fit perfect.
The upper mounting holes on the alu hub...the 2 'lower' ones are on the same height as the ones on the plastic hub. They added 2 above them, so that gives you just 2 new setup options.
Just browsing at the Japanese Kyosho site on 'new parts'..there seems to come an ifw411 item...bablefish translates it into something titanium for a light weight chassis
Matthijs is offline
Old 12-08-2009, 07:51 PM
  #2826
pitpop's Avatar
Hi Guys. The IFW410 hubs will be at K-America in about 3 weeks. As mentioned they don't use the inserts, but you need to use Kyosho bearings because the tolerance is very tight. The price is in the 60 range but I don't know officially for sure yet. 5775 yen is about 65 bucks so pretty close...
pitpop is offline
Old 12-09-2009, 01:31 AM
  #2827
mp9er's Avatar
Post cody's new set up
hi pitpop just curious about cody's set up from revelation raceway is that his new base set up or is it slightly adjusted from base hopefuly you can reply cheers
mp9er is offline
Old 12-09-2009, 05:45 AM
  #2828
vince7870's Avatar
Trader Rating: 15 (100%+)
Hi pk,,,,,have you guys gotten a chance to run new Rear hubs? Have you tried any of the new holes? Any feedback would be appreciated, thanks
vince7870 is offline
Old 12-09-2009, 07:38 AM
  #2829
playerdd's Avatar
IFW411 will be a titanium screw set for the MP9. don't ask me for the content, because i haven't seen any pics of it, yet.
playerdd is offline
Old 12-10-2009, 12:58 AM
  #2830
Matthijs's Avatar
nice info Frank! No Nitromania for you? I think there are some spots left in the BL-class, you're fast with the mp9E
Matthijs is offline
Old 12-10-2009, 11:15 PM
  #2831
pitpop's Avatar
Hi guys. MP9er, yea, we recently made some tweaks and are running the short rear camber link and less toe in. The car just seems to get round the track more quickly. We will use this everywhere unless severe conditions call for changes (which usually happens lol).
vince, haven't run them yet, but we are anxious to try. I am really glad there is vertical adjustability for camber link position. That can be very helpful.
Oh yea, almost forgot, here's a couple videos for you guys...
http://www.youtube.com/user/SPRCVIDEO#p/u/0/yKx6L2ZfHME
http://www.youtube.com/user/SPRCVIDEO#p/u/3/tb8EhWTr-uU
pitpop is offline
Old 12-11-2009, 07:37 AM
  #2832
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
Default Mp9 tki
i have one race season on my mp9 and im restoring it for this coming season and i was wanting to get a new chassi and i saw foroni made one on amain are any of your guys using that one? (Fioroni Kyosho MP9 Hard Coated Ergal Chassis) or am i better off getting the Kyosho chassis? my plans were to replace all bearing thruout the whole car,get the updated diff cases,updated front upper arms,updated rear carriers.... i perdy much have all of my spares from last season front hubs,rear hubs,wingstay,all bushings,ive checked all the diff cups and there hardly any wear on them, the only thing i really broke last year was front arms 2 to be exact so i would like some suggestions on what all to update? the hings pins thruout the car r in real good shape and all drive axles seem to be also in great shape!!
also i use the stock pistons?? is there a better piston combination than the stock?
another ? the rear stock toe brace what degree is that? if434
bigBoyBigToy is offline
Old 12-11-2009, 08:50 AM
  #2833
Trader Rating: 19 (100%+)
Default MP9 setup
Does anyone have a good baseline setup using the med. shock tower and shocks in the rear.
Chartos is offline
Old 12-11-2009, 11:46 AM
  #2834
rdeppen's Avatar
Bigboytoy. I'd save the money. You can get a stock Kyosho chassis from ebay for less then $50.00
I scored one for for $38.00 2 weeks ago. I'll never spend $100.00+ on an aftermarket or stock chassis again as long as people are parting kits
rdeppen is offline
Old 12-12-2009, 02:36 PM
  #2835
This is Davids normal setup that he always start with.
File Type: pdf
PiRo is offline
