Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-04-2009, 11:37 PM
  #2806
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 101 (100%+)
Anyone ever use those white teflon AE clutch shoe spacers at all? I noticed that the shims that came with the SE kit are way to thin, the shoes tend to rub or even hang on the end of the flywheel. Would have to put a real big chamfered edge on the bottom of the to make it work.
This is what im talking about... Ill try em on my next rebuild.
BSchorr is offline
Old 12-07-2009, 05:54 AM
  #2807
MikaR's Avatar
Hi, just wondering if anyone is using (or has experince) Futaba 2.4gHz receiver with High Voltage servos and a lipo RX pack without a regulator?
So, in other words - Can the Futaba RX handle 7.4 volts for a prolonged time ? I've been table testing and it all looks good, but what about in real driving conditions?
Any experiences there? Appreciated, thanks.
MikaR is offline
Old 12-07-2009, 07:53 AM
  #2808
Gizmatron's Avatar
not tried it myself..I know people who use 11.1v lipo packs in the 3pk transmitters which are rated for 9.6v but I wouldn,t do it myself..If you blow it any warranty is void and replacement units aren't exactly cheap ..I use life packs..same advantages as the lipo don't go flat when not in use plus you can charge at 15c or up to 30A if you have a charger that can handle it..not fragile either like lipo's and TX/RX packs are 6.4V and 9.9v..I can provide ebay links for various packs to fit various radios at good prices if you want...
Gizmatron is offline
Old 12-07-2009, 09:46 AM
  #2809
didrace's Avatar
any lipo for nomadio react?
didrace is offline
Old 12-07-2009, 10:16 AM
  #2810
MikaR's Avatar
Actually, I've been using a 11.1 lipo for my 3pk transmitter for this year.. now I'm concerned of the RX if it can handle 7.4 volts... my servos are lipo ready .. http://www.hitecrcd.com/servos/show?name=HS-7940TH
MikaR is offline
Old 12-07-2009, 10:48 AM
  #2811
Gizmatron's Avatar
yeh I know about the lipo ready hitecs...I just don't want to risk my spektrum and futaba stuff with excess voltage..
and re nomadio react..no idea what configuration is it..hang on i'll grab the ebay listings for LiFe packs
http://desc.shop.ebay.fr/ukrc/m.html...sacat=0&_rdc=1
they list packs for futaba 3pk and 4pk and ko propo if the nomadio takes any of these..
Old 12-07-2009, 11:03 AM
  #2812
Jammin57's Avatar
Trader Rating: 120 (100%+)
He is asking about a rx NOT a radio
I don't know anybody that runs unregulated lipo of the fasst rx's I think they are only rated for 6volts I would not suggest it but that's up to you
Jammin57 is offline
Old 12-07-2009, 01:26 PM
  #2813
Gizmatron's Avatar
the original poster was yes and I posted the exact same reply as you but I think if you scroll up a couple of lines you'll see a request for lipo availability for a nomadio react which last time I looked was a RADIO!!!
Old 12-07-2009, 11:41 PM
  #2814
DO NOT DO IT, The fasst receiver only takes 6v maximum, it stats so on the owners manual, an I blew a new receiver and two servos by ignoring that., lucky me all got replaced for free, but I dd get note frm futaba that the receiver failled due to over voltage, I was running the losi lipo with a 6.5v regulator. Since then made the switch to the DX3 no more issues (the 3pk is still a superior radio a far as functions, mixing, etc)
RAlmeida is offline
Old 12-07-2009, 11:48 PM
  #2815
MikaR's Avatar
Thanks folks for your responses!
I talked to couple of local guys, they've been using lipo ready servos and haven't got any issues with the futaba receiver.. the other works in hobby shop and apparently wasn't aware of any of the cases where the futaba RX would have died when using 7.4 volts..
But I'll think about the DX3R because I would need another RX anyway...
MikaR is offline
Old 12-08-2009, 12:20 AM
  #2816
So I was wondering if anyone has put the new werks b5 in the mp9? Anyone tried it or had experience with this combo?
-Thanks!
freestylinmotox is offline
Old 12-08-2009, 04:53 AM
  #2817
mp9er's Avatar
Post rx lipo futaba
hi mikaR yes you can run 7.4v lipos with your 4pk rx and servos with no regulator as long as you have decent servos. I am currently running 7.4v orion 2s 1p with no regulator and futaba brushless servos direct link up with no switch RACE TESTED no broblems what so ever.
mp9er is offline
Old 12-08-2009, 05:07 AM
  #2818
MikaR's Avatar
Thanks!!
But you know what - I already purchased a DX3R radio with 2 receivers to be on the safe side. I would have needed another futaba RX anyhow, so the price difference between a single RX and a new radio is tolerable.. and it will be interesting to try this new radio anyhow... Plus that I've had heat issues with the futaba 2.4gHz receiver, though I got rid of them by placing the receiver in the outmost corner of the radio box. DX3R haven't got any heat issues, at least that I'm aware of.
MikaR is offline
Old 12-08-2009, 05:18 AM
  #2819
mp9er's Avatar
Thumbs up
i beleive that would be the first batch of receivers but good luck with new radio set up m8te
mp9er is offline
Old 12-08-2009, 05:32 AM
  #2820
MikaR's Avatar
Oh, that's possible. That got me thinking.. I changed the receiver to the newer one I have, too, and it hasn't got heat issues since.. oh well. Hope the new radio is good, Thanks! At least it should be lighter.
MikaR is offline
