Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 11-09-2009, 01:41 AM
  #2686
Originally Posted by foampervert
hiya folks,
I'm keen to purchase a one peice engine mount for the Mp9, I can't seem to locate any manufacturers that does it specifically to MP9 specs though, only for mp777 or earlier cars.
If anyone has any idea who is making mp9 one piece mounts, please send me a link?
Shalom and God Bless!
-Alexander
king headz?
amonmp9 is offline
Old 11-09-2009, 01:49 AM
  #2687
speedy2's Avatar
http://www.kingheads.com/index.php?c...b82b0725942543
speedy2 is offline
Old 11-09-2009, 03:57 AM
  #2688
Matthijs's Avatar
hiya folks,
-Alexander
why would you want something like that? The stock system is one of the easiest I've ever used.
Kingheadz & Reckward Tuning (RMV) are the one's I remember.
Matthijs is offline
Old 11-09-2009, 09:09 AM
  #2689
Originally Posted by KWT-NITRO
Hello Kendall,
just a small question about the oils, i use Ultimate racing oils and they are great, they run with numbers like 40/45/50 and so on, but i'm not sure if they correspond to the same viscousity of losi oils... any ideas about the conversion??
cheers
Ali
hmm, good question Ali. I use this chart here to determine what wt/cts to run in the shocks. http://www.twf8.ws/php/tip/shock.html I believe this was before Ultimate came out with their shock oils. Check the bottle to see if they have a cts rating on there. The chart link above tells us the Losi 40wt is supposedly around 550 cts, but if you look at other brands like Serpent 40wt, its over 1000 cts; therefore you really should make sure you know the cts before you put a specific brand of oil in your shocks. You could maybe send Ultimate an email regarding what the cts is of each wt they sell; that would be the best option I think.
Kendall
KendallWelch is offline
Old 11-09-2009, 08:33 PM
  #2690
RCworks216's Avatar
Trader Rating: 26 (96%+)
anyone know what size the MP9 shock are? big bore 16mm or???? never own a kyosho but im thinking of getting a used one.
RCworks216 is offline
Old 11-09-2009, 09:05 PM
  #2691
Pretty sure its 16.
Old 11-09-2009, 10:46 PM
  #2692
Twitchy Kanai's Avatar
My original rear bulkhead finally died this past weekend racing in RC Pro International Finals. I guess I should have chaged it to "C" version b/c it broke while I was running 2nd in B-Main ready to bumped to A.
Twitchy Kanai is offline
Old 11-10-2009, 04:00 AM
  #2693
i have a question
as regards SHORT POST SHOCK
i need 2 measures.
from upper hole to inf hole (shock hole, ad inferior uniball hole) with the shock at maximum leght
from hole to hole with shock compressed
it s possible?? thanks, sorry for my bad english
amonmp9 is offline
Old 11-10-2009, 07:54 AM
  #2694
foampervert's Avatar
Default just wondering...
I read somewhere that a stiff engine mount will allow the engine to work better as there is less stress on the engine body. From an engineering background, this has merits, not sure how much stress is introduced at the chassis to cause engien crankcase to warp and rob valuable power?
apparently this phenomena is not as obvious with 'old school' engine brands like OPS, Picco, Rossi... and more apparent with 'newer' engine makers; OS, Novarossi, Sirio, GRP
Not that I am lacking power, just thought it might help keep the engine healthy longer
-Alexander
foampervert is offline
Old 11-10-2009, 01:09 PM
  #2695
KWT-NITRO's Avatar
Kendall
Hey Kendall, thanks for your input, ill check with our Ultimate racing dealer, i'f am not mistaking , 40= 400cts 45=450cts ...etc etc
i normally run 40 rear 45 front when the weather is a bit cold, sometime i drop to 40/35 when its freezing cold....when the temp raises, i go to 55/60.
my other question: the stock pistons are 8/1.2 right?? now, why would i want to change to the newer ones like the 8/1.3 or the 6/1.4 or 5 i'm not sure, will i really feel it while driving?? how will you explain it easily for us, i mean can you tell us what type of track needs what?? do you see what am sayin?
cheers
Ali
KWT-NITRO is offline
Old 11-10-2009, 02:43 PM
  #2696
Trader Rating: 29 (100%+)
cheers
Ali
no, 32.5=400cts, 37.5=450cts, and so on
slayyer is offline
Old 11-10-2009, 05:54 PM
  #2697
cheers
Ali
Slayyer, those are the numbers for the Ultimate oils?
Ali,
Yes made perfect sense. Yep, stock pistons are 1.2x8 on the TKI, but I have heard it comes with 1.2 and 1.3 on the SE? (I don't have the SE yet) Changing pistons is all about personal preference and what the track is doing. For example, the RC X Fest race up here in Minnesota is known to be a very rough and sandy track. In this case, some may want to go more holes in their pistons (rear especially). This will give the suspension "less pack" and go over the rough better. So instead of 1.3x8/ 32.5 wt Losi in my rear shocks, I drilled them out and ran 1.3 x10/ 35wt Losi. You have to go up in oil to compensate for more holes.
Typically, one would want to run more holes for more side bite, and less holes for less side bite and response. Notice how on the STRR, mostly everyone runs 1.3x6, this is so we are able to slide the trucks around a bit more through the turns. If you have an extremely smooth track, I could see going to a 1.3x6 or 1.4x5 piston. The car would generate less chassis roll and could be faster. On the old 777 we used to run 1.3x6 on the front and 1.3x8 rear to calm the car down, the same can be said for running 1.2 front and 1.3 rear on the MP9. Kyosho also makes angled pistons. These will make the car feel stiffer landing jumps, and would make the car pop more off the jumps. So far I haven't noticed too much of a difference between the angled and straight pistons though.
Usually I will have specific oils to run with specific pistons. If I run 1.2x8 front pistons, I'll throw in 35 wt Losi. Now I have 1.4x8 angled/ 40wt Losi. Rears- 1.2x8/ 25wt, 1.3x8/ 32.5wt, 1.3x10/ 35wt. Once I tried the rear shocks in hole number 2 on the tower (second from inside) with 40 wt, that worked pretty good as well. Had to go to a thicker oil to compensate for the low, soft shock angle. I might go up or down 2.5 wt depending on what I want the car to do, but those piston settings are pretty much what I run.
You have the adjusting temperature/oil settings down pretty good. I personally don't change oil too much depending on temp because the Losi oil doesn't change viscosity a whole lot. I will only go +/- 2.5 - 5wt in say a 30-50F degree temperature change.
Hope that helps
Kendall
Old 11-10-2009, 06:02 PM
  #2698
jpalessi's Avatar
Trader Rating: 55 (100%+)
how many of you guys run the stock k filter cage?
jpalessi is offline
Old 11-10-2009, 06:05 PM
  #2699
22Racer's Avatar
Trader Rating: 67 (100%+)
I always use the stock filter cage, I've seen others not use it. I think either way would work fine.
Rex
22Racer is offline
Old 11-10-2009, 06:45 PM
  #2700
counterman's Avatar
I use the stock filter set up and like it. Why buy anything different.
counterman is offline
