Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 11-04-2009, 01:10 PM
  #2671
Trader Rating: 28 (100%+)
Does anyone have an updated set-up sheet from Cody or Tebo? I'm wondering what shock oils they are using with the green and blue springs.
bphil49 is offline
Old 11-04-2009, 06:39 PM
  #2672
Anyone with a MP9 SE or a TKI with the Med. Rear shocks. How much droop are you using, I read somewhere 116mm. What does this equate to if measuring droop from the bottom of the rear hub carrier to a flat surface?
motorhead68 is offline
Old 11-04-2009, 07:01 PM
  #2673
Cody is running the same oil as he did with the old springs.
KendallWelch is offline
Old 11-04-2009, 07:15 PM
  #2674
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 101 (100%+)
I would like to know that to MotorHead!!!!! Someone needs to measure from the chassis to the buttom of the hub.
Ive been running the arms touching the chassis, and then having the screw touch the chassis, then give it 1 full turn once it touches the metal
Whats everyone's favorite front and rear shock pistons and oil?
BSchorr is offline
Old 11-04-2009, 07:27 PM
  #2675
Yeah, I read that Tebo prefers to put the car on a buggy wheel and using calipers measure from the bottom of the hub carrier to the table. Im trying to see if its possible to hit the same droop measurements with the long and med rear shocks. Both my cars have the long shocks on them.
As far as shocks, I like 1.2x8 35 wt Front and 1.3x8 30 wt Rear
Old 11-04-2009, 09:02 PM
  #2676
Lately I've been messing around with 1.4x8 angled front pistons - 40wt Losi front/ 1.3x10 - 35wt Losi rear. Less pack.
Here is a link to all the setups I've messed with in the last year or so. Most are for the MP9, some others for the STRR and a few for the WC. I don't think I have the updated STRR setup on there though, its 10/15/2.
http://s291.photobucket.com/albums/l...welch/Setups/?
I should be testing the new 1.4 springs this weekend. I'll let you guys know how they compare.
Old 11-05-2009, 07:08 PM
  #2677
RickyBobby619's Avatar
we have been running 120mm droop in the rear. The most I've seen is almost 124mm maxing out the med shock set-up. I'm thinking of changing my SE to the longer TKI so I can achieve a lil more droop to keep the inside rear tire planted in the corners? I've noticed s lot of tire lift with the SE setup snd the buggy wants to slide out.
RickyBobby619 is offline
Old 11-05-2009, 07:28 PM
  #2678
counterman's Avatar
I'm running 122mm of droop in the rear with 35wt losi ft and 30wt losi rear and my son's running 121mm with 32.5 ft and 27.5 rear.
His car is easier to drive but less responsive and doesn't pop of the jumps as well as mine.
counterman is offline
Old 11-05-2009, 09:01 PM
  #2679
Any Kyosho guys running the new werks b5? Ive heard good things about it. at 200 bucks and getting 10 min. a tank with buggy, its hard to pass up. Any experiences with this motor with the mp9?
-Thanks
freestylinmotox is offline
Old 11-05-2009, 09:15 PM
  #2680
Timmo's Avatar
Trader Rating: 16 (100%+)
Will the MP9 brake disc and pads work on any of the other Inferno buggies??
Timmo is offline
Old 11-06-2009, 05:42 AM
  #2681
counterman's Avatar
Yes they should. I am running vented rotors from my 777wc on my MP9 and they work great.
Old 11-06-2009, 09:31 AM
  #2682
KWT-NITRO's Avatar
Hello Kendall,
just a small question about the oils, i use Ultimate racing oils and they are great, they run with numbers like 40/45/50 and so on, but i'm not sure if they correspond to the same viscousity of losi oils... any ideas about the conversion??
cheers
Ali
KWT-NITRO is offline
Old 11-06-2009, 09:57 PM
  #2683
Timmo's Avatar
Counterman,thanks..
Timmo is offline
Old 11-06-2009, 10:08 PM
  #2684
BSchorr's Avatar
All I can say, the solid rotors that come with the SP kit dont have enough braking for me when I need it! Im going to modify them by drilling 6 holes in them before I spend the bucks buying vented ones.
BSchorr is offline
Old 11-08-2009, 05:18 PM
  #2685
foampervert's Avatar
Default one peice engine mount
hiya folks,
I'm keen to purchase a one peice engine mount for the Mp9, I can't seem to locate any manufacturers that does it specifically to MP9 specs though, only for mp777 or earlier cars.
If anyone has any idea who is making mp9 one piece mounts, please send me a link?
Shalom and God Bless!
-Alexander
foampervert is offline
