Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 10-20-2009, 07:26 PM
  #2641
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Originally Posted by jono mad racer
Hi Guys, What is the main difference between the Stand MP9 and MP9 TKI?
Ok, I see the difference in parts and anodizing etc , so what does this mean on the track, tki vs se. Is there much difference between them?
flame56mx is offline
Old 10-20-2009, 07:29 PM
  #2642
BSchorr's Avatar
Trader Rating: 101 (100%+)
Nothing... Its a more "budget type car"
BSchorr is offline
Old 10-20-2009, 07:53 PM
  #2643
Hey Ben, you have the SE?
Old 10-20-2009, 08:03 PM
  #2644
BSchorr's Avatar
Yes sir
BSchorr is offline
Old 10-20-2009, 11:01 PM
  #2645
i use D8 brake in my TKI, they work TOP.
D8 disk, and losi modified brake pad
amonmp9 is offline
Old 10-21-2009, 05:20 AM
  #2646
shinnbad12's Avatar
Originally Posted by BigRed
I picked up a used TKI version, apparently it was a little more used than I thought. So i'm replacing a bunch of things to tighten up the car. I would like to get off-power steering, Right now I have a little of push.
Need to see your whole set up. I run 6,000 in the front and some times 7000 with NO push Castor ? Ride height ? Sway bar (in front ) ? Where upper A arm shims are ?
shinnbad12 is offline
Old 10-21-2009, 05:16 PM
  #2647
shinnbad12's Avatar
Originally Posted by DirtRacer (Irl)
@ Shinnbad12
I like your diff set-ups by the way!
Thanks DirtRacer, At our last outdoors I ran 6,5,6 just to try so I would know. The track was WET, not muddy but very tacky. The car was AMAZING, but the next weekend we had to start running indoors and those diffs. do not work . It still turned in good but way to much rotation Our indoors is clay and starts out tacky in practice and turns dry for the mains. I went back to last years set up with the diffs. F,C,R 7,5,4 It was real good. Turn in, middle of the corner had some rotation and on power corner exit was PLANTED
Makes me wonder why anybody would run anything other than a MP9
Old 10-22-2009, 12:09 AM
  #2648
Hi Guys,
I've been searching for these new Kyosho springs i cant seem to find much about these at all.
Is anyone here running them yet?
Also where can i get some from too.
No.IF348-1014 (M & L / Light Blue / 10-1.4 / L = 95)
No.IF348-1114 (M & L / Green / 11-1.4 / L = 95)
No.IF350-714 (S / light blue / 7-1.4 / L = 70)
No.IF350-814 (S / Green / 8-1.4 / L = 70)
carlin is offline
Old 10-22-2009, 01:15 AM
  #2649
Matthijs's Avatar
Originally Posted by carlin
Hi Guys,
Kyosho USA has them in stock, should take a few weeks and their available at Amain's etc. I got them from a hobby shop in Japan, released on 28 september. I guess available in Europe in a month or so. I run them, with the ligt blue on front and the green on back you have one small step stiffer from the lime green and purple stock setup. Nice tuning option.
Matthijs is offline
Old 10-22-2009, 02:05 AM
  #2650
Thanks for that will order some from the US then.
Cause we dont have them in the UK been waiting for month nearly.
I know some of the team drivers only just got them, seems to be struggle in the UK for new bits lately.
carlin is offline
Old 10-22-2009, 05:01 PM
  #2651
Anyone with the Mp9 SE, can you tell me if it comes with 91 or 93 mm driveshafts? I have a tki and I know that comes with 91 mm.
motorhead68 is offline
Old 10-22-2009, 08:36 PM
  #2652
Hey guys looking at getting the mp9 but don't know what one to get as i've only been able to find the standard edition but have been told of another edition. just want to know what are the differents between them and are the differentses worth it or is the standard just as good? any ifo would be great thanks
twitch_1 is offline
Old 10-22-2009, 08:41 PM
  #2653
Dyno-Dylan's Avatar
Trader Rating: 36 (100%+)
The differences are explained one page back in this thread. Either car is good.
If anyone knows, Id also like to know if the MP9 SE comes with 91 or 93 mm driveshafts.
Dyno-Dylan is offline
Old 10-22-2009, 10:23 PM
  #2654
ottofung's Avatar
It (SE) comes with 91mm driveshafts.
ottofung is offline
Old 10-27-2009, 07:25 PM
  #2655
Trader Rating: 29 (100%+)
what reciever battery fits in the mp9? looks like a stick would fit because it doesnt look big enough for a hump. thanks!
slayyer is offline
