Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-12-2009, 10:30 AM
  #2281
upgrade front upper arms
and...
upgrade rear hub... i think... the photo is not perfect
amonmp9 is offline
Old 07-12-2009, 10:39 AM
  #2282
ezveedub's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Matthijs
let's see who awake ;-) find the new parts (J. Aigoin at the Euro's final)
I can't really see anything different from that picture at all.
ezveedub is offline
Old 07-12-2009, 10:40 AM
  #2283
Grimm0ne's Avatar
i would need to see what it looked like before lol.
Grimm0ne is offline
Old 07-12-2009, 10:45 AM
  #2284
ehames005's Avatar
Trader Rating: 74 (100%+)
The front shock stand offs are alot thicker
ehames005 is offline
Old 07-12-2009, 10:49 AM
  #2285
ezveedub's Avatar
The fronts are AL and the rears are stock steel. Not sure why he mixed them up.
ezveedub is offline
Old 07-12-2009, 10:59 AM
  #2286
no no no...
front tower and rear tower i think are normal TKI tower...
see the LOWER part of the ant C hub......
lower part... do yu see anything??? i see a screw.....very long....
amonmp9 is offline
Old 07-12-2009, 11:19 AM
  #2287
captain america's Avatar
Originally Posted by amonmp9
no no no...
That's right, the normal kit part has a recess for the screw head; this one clearly has the screw head sticking out. New part?
The pics made me realize something else: my SE kit comes with different "lightened" rear wing pylons. The TKI edition pylons have cut-outs and (I think) aluminum cross-braces, whereas the SE has reinforced pylons (no cut-outs) and plastic hex braces.
captain america is offline
Old 07-12-2009, 12:12 PM
  #2288
ezveedub's Avatar
I can't tell you what the SE kit really has, but the TKI didn't come with AL wing mount braces or radio tray mounts either, they are option parts. On the C-Hub screws, it could have been falling out, LOL! Its happened before.
ezveedub is offline
Old 07-12-2009, 12:53 PM
  #2289
the modification in the aigoin s car is made to prevent it
amonmp9 is offline
Old 07-12-2009, 12:59 PM
  #2290
Haha, you're right. Guess someone might've forgotten to threadlock their screws.
Actually, I have another question: does anyone use the included grey spacers under their center diff mounts with the stock spur? The manual says to use them if running the optional 48T spur, but I noticed that without any spacers, the stock spur protrudes barely 1/10 of a mm below the chassis. Not much, but wondering if that's enough to cause problems?
Old 07-12-2009, 01:14 PM
  #2291
ehames005's Avatar
I do not use them and I have had no problems yet
Old 07-12-2009, 01:43 PM
  #2292
Matthijs's Avatar
I don't use them, no problems..
On Jerome's car..in the final he appears to be using black inserts (and the rest of the updated parts) ;-)
Matthijs is offline
Old 07-12-2009, 02:04 PM
  #2293
ezveedub's Avatar
Same here, no spacer and no problems.
ezveedub is offline
Old 07-12-2009, 03:11 PM
  #2294
jerome told me that he colored the kyosho insert with black color^^ lol
amonmp9 is offline
Old 07-12-2009, 08:09 PM
  #2295
shesha's Avatar
Looks like Kanai was the only one testing the parts on the mp9.
Jeromes looks likean updated TKI with latest parts nothing out of the ordinay other then the gas cooler being used which looks like a team titan gas cooler...
shesha is offline
