Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-22-2009, 03:39 PM
  #2086
shesha's Avatar
discontinueing the the TKI version of the MP9 already wow.. that will boost the sales even further....
shesha is offline
Old 06-23-2009, 12:25 AM
  #2087
Matthijs's Avatar
don't be surprised if this is complete BS. Propably just a story from a local hobby shop to sell the kit he has in stock.
For you kit, get some extra springs. Stock are the purple ones (black in your kit), order some lime green up front (short version) and lime green in the back (medium version). To be complete...some whites in front and back (on very slippery tracks).
Matthijs is offline
Old 06-23-2009, 05:17 AM
  #2088
SQC049's Avatar
Trader Rating: 18 (95%+)
I heard the same thing when I ordered my Standard edition from my LHS.
SQC049 is offline
Old 06-23-2009, 07:42 AM
  #2089
Default Oil conversion, Kyosho to AE?
My LHS has several Kyosho shockoils on backorder and a different LHS around the corner is a AE-dealer and has all the different weights in stock so
Im thinking that I could temperarily switch brands.
Does anybody know what the Kyosho weights is in AE numbers?
Thanks.
harleyrules is offline
Old 06-23-2009, 08:32 AM
  #2090
Allumina's Avatar
Trader Rating: 27 (100%+)
Thanks.
Hey man, use this calculator to figure out the correct oils
http://www.offroad-cult.org/Special/...wt_convert.php
I use Associated oils in my cars [shocks and diffs] just because its half the price... and no one carries Kyosho anything locally, so I just roll with what i can get
Allumina is offline
Old 06-23-2009, 09:40 AM
  #2091
Thanks, that was a really good calculator.
Old 06-23-2009, 10:04 AM
  #2092
1000 wt approximately correspond to 22187 cps.
lol
LOSI 5000wt is similar to kyosho 5000 CPS???
amonmp9 is offline
Old 06-23-2009, 11:40 AM
  #2093
I broke my car for the first time in the 6 gallons that I put through it on sunday. The C hub snapped at the lower king pin, I snagged a huge nail that was stickijng out a bit coming off a triple during practice before racing. Anyway, I didnt have any replacements so I got a bit creative with a MP777 c hub. It fits almost perfectly, you just need to shave off some material on the inside so it doesnt bump up against the lower arm, preventing the proper camber adjustment, then add a shim between the kingpin and the knuckle to get rid of the slop and your good to go. Well... you gotta adjust camber and toe again but then you all set. Geometry is a bit different but I didnt notice it too much, the car drove great...
So if you're ever in this situation, you'll know what to do.
BTW a 7.5 c hub will fit as well, I tried that first but it'd take a bit more time cuz the ball holding the hub to the upper arm has flanges on the 777 and mp9 so you'd have to shave off more material (theres plenty of it).
Paul B is offline
Old 06-23-2009, 01:59 PM
  #2094
Good job, got to do almost anything to keep racing!
Old 06-23-2009, 02:04 PM
  #2095
Cannondale1974's Avatar
Trader Rating: 33 (100%+)
I'd like a comparison between the Xray 808 and MP9 regarding handling/performance only. I have a brand new 808, have yet to drive it though. I drove an MP9 this weekend and fell in love, simply the best handling buggy I've ever driven, period. Felt SO light and responsive, turned on a dime, braking and acceleration was incredible.
I realize this is the MP9 thread and many will be biased towards what they own, however your impartial feedback is appreciated. Thanks!
Cannondale1974 is offline
Old 06-23-2009, 02:22 PM
  #2096
houston's Avatar
Trader Rating: 96 (100%+)
very nice pat
houston is offline
  #2097
houston's Avatar
and the mp9 is a bada$$ car that almost drives itself when properly setup
houston is offline
Old 06-23-2009, 02:27 PM
  #2098
shesha's Avatar
Looks like the BS is not BS after all, it looks like solid information....Kyosho going to stop TKI edition and going for the STD.
shesha is offline
Old 06-23-2009, 02:36 PM
  #2099
Grimm0ne's Avatar
works for me cuz im poor hahah...
but kicking around ether picking up a MP9 or MBX6, as the last thing i drove on the track was a KE3 so its been awhile. Any pointers from my fellow Kyo drivers or should i just go Mugen ahha. (don't flame me, im on a budget and the wife will kill me when she finds out)
Grimm0ne is offline
Old 06-23-2009, 02:55 PM
  #2100
What information are you refering to? Are you jsut being sarcastic or serious?
I'd cry if they got rid of the TKI version
Paul B is offline
