Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 10-03-2018, 01:41 PM
  #20026
Are the tki4 radio tray, upper steering and center diff mount plates interchangeable with tki3 and vice versa? Im looking to upgrade my stock tki3 plates to aftermarket carbon ones produced for "tki4"
any insight much appreciated!
sn47som1 is offline
Old 10-03-2018, 08:45 PM
  #20027
Trader Rating: 16 (100%+)
They sure are. I too have replaced the steering brace with a carbon fibre part from T-Works RC. Also got their carbon fibre transponder mount. For the money, I think they have some awesome bits and pieces. Really want to try their new hard anodised brake cams and their steel diff gears. I donít advise using their titanium turnbuckles though. I tried them a few years ago and went back to Lunsford. Donít think you can beat Lunsfordís lifetime warranty.
But RC T-Works definitely have some really interesting new parts for our cars. Bout time too, Iíve been asking them for years when theyíre gonna start releasing some more bits for the MP9 and seems theyíve finally stepped up their game.
aaron125 is offline
Old 10-04-2018, 03:22 PM
  #20028
Nice! yea i figured that out after posting haha.... I've been managing so many parts and multiple websites mixing and matching parts and price for the past 2 days! im spent. But this mp9 build is going to be epic! I'll post pics when its done. I have that on order with the switch plate and the rest psm plates! better quality stuffs. Tworks is awesome value. I've had bits and pieces in the past from them never had issue. fitment was good, quality was good and can't complain about the price. I'm really pissed the rear suspension block hinge pin kit from m2c has been out of stock for ages Id love to pick that up.
sn47som1 is offline
Old 04-10-2019, 11:56 AM
  #20029
The tworks parts came in and they are good quality. Of course not as good as Fioroni or Kyosho but not far off. The anodizing is definitely nice and fitment is good. Very good products for the price but I won't be using them in my final build. It will be all Fioroni and Kyosho parts. I have the hard coated brake cams and the hard coat diff gears. I haven't installed the cams yet, but DON'T buy the diff gears! What a gigantic disappointment. They aren't even cut right because of this are not useable- repeat aren't useable. They don't even fit the diff case. The sun gears are too tall and not even cut the same shape it's just awful. I bought 3 sets for all diffs too! Now they are paperweights. Hopefully the cams are right.
Do you know if there are any other manufacturers cvds' or driveshafts that fit the MP9? I am looking for other Manufacturers cvd kits or driveshafts from other manufacturers that fit the MP9 wheel axles. Thank you
sn47som1 is offline
Old 04-19-2019, 07:11 PM
  #20030
Car lost connection and went full throttle into the curve.
Chassis is bent.
Niz55 is offline
Old 04-19-2019, 07:12 PM
  #20031
Niz55 is offline
Old 04-19-2019, 07:14 PM
  #20032
Niz55 is offline
Old 04-20-2019, 12:14 AM
  #20033
Palebushman's Avatar
Chassis is bent.
Oops, that's some serious damage for the sake of a couple of rubber bands.
Palebushman is offline
Old 04-20-2019, 02:21 AM
  #20034
An yet hes running it on the street? this is the same one who tested two kyosho buggys at kyosho america in a parking lot then completely ignored all advice he was given when he asked about them
iplaygames is offline
Old 04-20-2019, 03:14 AM
  #20035
What the hell is a rubber band going to so when I have a return string already? The servo stayed fully opened.
Only damage is bent chassis and top plates.
Niz55 is offline
Old 04-20-2019, 03:16 AM
  #20036
What is wrong with running it on the street?
And what advise you gave me?
Niz55 is offline
