Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-12-2016, 02:49 AM
  #19921
Trader Rating: 16 (100%+)
Originally Posted by My ST-RR EVO
It will work in either direction, but the screen (filter element) is where the o ring is. A long time ago someone in this TKI3 thread explained it's best to have the o-ring end toward the carb since the other end has more space to hold the junk the filter filtered and therefore will take longer to clog. Makes sense, but i never amassed so much stuff in my filter. FYI that filter is just a tube with metal screen going across it.
+1
Even better is to use a sintered brass or stone filter. They have far greater surface area and much finer pores than a simple mesh screen. I've been using a Dynamite Big Boy (I think that's what it's called) for several years now and never had a single issue. Still got 2 unopened brass filter inserts which I thought I might need some day. And they come in bling bling colours. I can't stand em, so use the grey/titanium coloured filter. They body seals SO much better than the kit filter and the filter body is larger than the kit filter so offers less reduction in fuel flow. Overall a heaps better option than the crappy mesh screen inserted in the kit filter. Essentially the Dynamite filter is a far better option than the kit part and with many engines in the $400+ price range it's really a bit ridiculous using the kit filter if you're not sponsored and have to buy and pay for your own engines. To use the kit part is almost doing harm to your engine imho. Buy one, you won't be disappointed.
aaron125 is offline
Old 06-12-2016, 06:12 PM
  #19922
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
Does anyone have any recent running vids of the car?
Posvar is offline
Old 06-12-2016, 06:27 PM
  #19923
Moderator
Posvar's Avatar
Should have stated I meant the tki4
Posvar is offline
Old 06-27-2016, 11:47 AM
  #19924
Trader Rating: 22 (100%+)
Has anyone ran a Agama A8 body on a MP9? Does it fit well?
jonasm48 is offline
Old 06-27-2016, 01:17 PM
  #19925
ROSCOE's Avatar
Trader Rating: 130 (100%+)
A8 body will be far too narrow. A215 may fit however.
ROSCOE is offline
Old 07-05-2016, 08:41 AM
  #19926
wittyname's Avatar
Currently I have a set up issue I don't want to just throw money at.
I have the 8x1.3 pistons , and with the set up oil weights the car felt good but would bottom on out largest double .
I went to a set of fioroni pistons I had with 42f and 37r . Car was money for the first 5 or 6 minutes of the heat , then would start landing crappy again. Went up to 50f and 45r just to see , and again it was awesome for the first 6 or 7 minutes , then started landing bad and costing me time.
I have the 5 x 1.5 pistons and I have the CSI blue pistons . I also think the 6x1.3 pistons might have the pack I need but I would have to buy them .
Thoughts on which pistons would land that large double better ? the 5x1.5s or the CSI blue ?
wittyname is offline
Old 07-05-2016, 04:51 PM
  #19927
BigInJapan's Avatar
Trader Rating: 18 (100%+)
I ran csi blue recently at a nationals round that bAsically consisted of doubles the whole track lol, anyway, 8 x 1.2 with 45 and 32.5 oils but was still not entirely happy with the pack. The 5x1.5's seemed to pack better even with lighter oils, definitely preferred those
BigInJapan is offline
Old 07-05-2016, 08:18 PM
  #19928
carpet Carlos's Avatar
Also, do yourself a favor and carefully dull the edges of the input /output nipples with sandpaper or a dremel, clean and put shrink wrap on over the fuel line where it goes over the nipple. The nipple has a tendency to cut the fuel line over time.
Yes ! I could not get my engine time right ruined a whole race not checking my fuel lines crazy.
carpet Carlos is offline
Old 07-20-2016, 08:42 AM
  #19929
tobamiester's Avatar
Trader Rating: 360 (100%+)
Found an error on Page 46 of TKI4 manual. I ordered new shock bodies which shows (in manual) IF470-01 as front. But received long 55mm Long Rear bodies. Manual has part#'s reversed. IF471-01 is Front 47mm bodies.
tobamiester is offline
Old 07-20-2016, 10:11 AM
  #19930
post it on Yuichi Kanai FB page
Andyg01 is offline
Old 07-20-2016, 08:07 PM
  #19931
I thought I noticed it. But paid it no mind
Old 07-20-2016, 08:39 PM
  #19932
yeah, ordered replacement front bodies..ended up with rears
Old 07-21-2016, 07:03 PM
  #19933
Nitroracer8's Avatar
Trader Rating: 14 (100%+)
Back to my old stomping grounds....KYOSHO!!!!!!
TKI4....
Nitroracer8 is offline
Old 07-21-2016, 07:15 PM
  #19934
Moderator
Posvar's Avatar
Nice!
Posvar is offline
Old 08-12-2016, 03:45 PM
  #19935
Tried searching, and didn't find any answers on this.
Is anyone running the Novarossi 4 shoe clutch? I think that clutch system uses a 34mm flywheel, and Kyosho runs a 32mm flywheel. Any issues? I would think the flywheel will protrude more, and increase chance of killing the engine if there is a chassis slap. If you are running this clutch....is the Nova clutch bell a requirement? Or will the latest vented Kyosho bell work.
Thanks - Greg
GAPaman is offline
