Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 05-24-2009, 11:17 PM
  #1951
i need an info.
in the TEBO set up he use camber -1
can someone tell me the measure of front superior arm and rear superior arm??
te measure of the visible gold metal...
thanks all (pay attention that there is the same upper rear arma position, tebo change it from the std position)
amonmp9 is offline
Old 05-25-2009, 05:16 AM
  #1952
Matthijs's Avatar
Originally Posted by amonmp9
i need an info.
I would suggest you to buy a simple cambergauge or a complete hudy offroad setup set. Also, don't copy a setup from somebody, start with the setup out of the box and adjust to your own liking and experience. That certain setup from Tebo may be right for that kind of track he was at, but that might be completely different from what your driving on (jumps, traction, ruts, etc..)
Matthijs is offline
Old 05-25-2009, 05:30 AM
  #1953
i have the cambergouge, and i have a my personal set up ..
i need the measure because cambergauge in off road is not very accurate...
only to try the tebo set up.
here in italy we use a very differente set up..
i love trying different approach to the car
amonmp9 is offline
Old 05-26-2009, 06:48 AM
  #1954
Key
Key's Avatar
Camber gauge will get the job done but when it comes to complete sets Hudy is not the top choice. HARD Racing or Kyosho's own are on par if not better:
http://www.shopkyosho.com/product/pa...87.25471.0.0.0
http://www.hard-racing.com/productio...7105&pageNum=2
Key is offline
Old 05-26-2009, 10:21 AM
  #1955
Key
Key's Avatar
Anyone know which of these Outerwears fit the Inferno filter?
http://www.amainhobbies.com/index.ph...cturers_id=240
Key is offline
Old 05-26-2009, 12:24 PM
  #1956
i think all. i use mugen filter on mp9, and i use the cilinder cover, with 2 plastic..... i dont know how to say in english.... FASCETTE ....
amonmp9 is offline
Old 05-26-2009, 06:12 PM
  #1957
2fst2c's Avatar
Trader Rating: 114 (100%+)
Searched the thread but didn't find the answer I was looking for. So, what starter box works the best for the MP9? I'm using a Crome top Ofna box now and it isn't the best fit. Kinda wide for the MP9. The suspension arms hit and I have to compress the suspension alot to get the chassis flat on the top. Looking for something narrower. Thanks.
2fst2c is offline
Old 05-26-2009, 07:32 PM
  #1958
foampervert's Avatar
Default you can't go wrong with a...
hiya 2fst2c,
you'll be delighted at owning a mugen box...
it's small, powerful, and all parts are available... it's like building a kit!
once you've owned a mugen box, you'll quickly realise why it's costlier but head and shoulders above the rest...
Shalom and God Bless!
-alexander
foampervert is offline
Old 05-26-2009, 07:38 PM
  #1959
2fst2c's Avatar
Any particular Mugen box or do they only make 1? Thanks Foam!
2fst2c is offline
Old 05-26-2009, 07:43 PM
  #1960
2fst2c's Avatar
is it this one?
http://www.amainhobbies.com/product_...oducts_id/1743
Looks as wide as the Ofna Crome top or is that an optical illusion?
2fst2c is offline
Old 05-26-2009, 08:52 PM
  #1961
ezveedub's Avatar
Trader Rating: 17 (100%+)
Use the Kyosho Multi Starter box 2.0. Configures for offroad or onroad, left or right side engine mounting.
http://www.amainhobbies.com/product_...oducts_id/9126
ezveedub is offline
Old 05-27-2009, 05:49 PM
  #1962
AndyMoore's Avatar
Trader Rating: 64 (100%+)
is it this one?
Yes, that is the correct one. Its not nearly as wide as the OFNA box, far more compact actually. It cant be beat.
AndyMoore is offline
Old 05-27-2009, 05:52 PM
  #1963
2fst2c's Avatar
Thanks!
2fst2c is offline
Old 05-27-2009, 06:05 PM
  #1964
Key
Key's Avatar
I prefer the Kyosho Multi Starter Box 2.0 over Mugen's. It's just as compact, narrower and perfect for the MP9. You'll never look back at another box.
Key is offline
Old 05-27-2009, 07:23 PM
  #1965
S Bowen's Avatar
Trader Rating: 57 (100%+)
I have the Kyosho starter box and have no problems and works great on my MP9.
S Bowen is offline
