Inferno MP9 thread
rear springs in orange and get the VRP 1.5x5 pistons and b00m all new car
Mmmmmm.....mine is new, just finished building it.....are there new towers and shocks that are different than the kit box....didn't managed to race it last weekend due to rain.
I just ordered a new RS chassis and it is definitely more flexible but it is also heavier which can be good on a bumpy track but..... it has no cut outs so you will want to drill a clutch bell hole for sure and probably also run the kyosho extended kyosho mount or a m2c/king heads quick change. I got it as we sometimes run buggys on road and wanted a bit more weight to keep my center of gravity lower.
These are the new longer front shocks and shock tower KYOIF485 and KYOIF484 springs needed KYOIFW457-8514 and KYOIS106-8514 then go to http://www.visionracingproducts.com and get the 1.5x5 pistons.
...then go to http://www.visionracingproducts.com and get the 1.5x5 pistons.
Im a slow driver, so im not crashed a lot. just wondering why my upper arms getting sloppy so easily,, is it happens on u guys too?
That's the way the upper arms are. The plastic seems kind of soft.
In some posts in the past some people asked about improvements for the next gen MP9. I'd like to see a normal camber link with balls on both ends for the front upper arm.
Hey guys just picked up a Kyosho MP9 TKI3 used only a few races old. Came with many hop ups but everything is stock setup. Anything I should get for it or am I good with stock? I bought a bunch of spare parts and some orange rear springs. Thanks for the help
Nevermind. I found it. If I could delete post I would...
Guys when you run this plate do you still have to put a hole in the chassis where the clutch bell runs? Or does this stop the flex enough.
about to buy a new chassis should i get the kit version or hard coated or m2c? Is there a difference from the kit and the hard coated? Feedback on the m2c please. thanks in advance
Rockstar what did you find to be the most noticeable gain from the ms front tower and shock setup?
Most run 1.3x8 Pistons. Just run it!
Agreed, I have had the extended plates since before they were released and it does still hit the chassis. It doesn't hit them as bad but it does still hit. You could probably get away with using a drimmel and just taking a bit of material away, but drilling is much faster and easier. This is what I will also do with the RTR chassis as they have NO cutouts compared to the other chassis.
