Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 10-15-2015, 10:53 AM
  #19336
dameetz's Avatar
Can anyone post a good set up for a very bumpy track? I m building shocks right now and wondering what oil to use. Our LHS has some Kyosho oil as well as other brands in CST.....pls advice.....this weekend will be my first race with this car.
Thanks.
dameetz is offline
Old 10-16-2015, 10:54 PM
  #19337
golferdude1971's Avatar
Trader Rating: 18 (100%+)
Thanks.
Check your pm's, I sent you a few links to some popular setups.
golferdude1971 is offline
Old 10-17-2015, 09:54 AM
  #19338
dameetz's Avatar
Thanks dude...
dameetz is offline
Old 10-18-2015, 03:30 AM
  #19339
Can we use a 34mm flywheel on this? I believe they recommend 32 but i only have 34 and dont want to buy new ones. thanks
Gavel is offline
Old 10-18-2015, 06:44 AM
  #19340
carpet Carlos's Avatar
I run a 34 with the mp7 motor mount
carpet Carlos is offline
Old 10-18-2015, 11:40 AM
  #19341
I use a 34mm on the MP9, it's a little close to sticking past the chassis but haven't had any issues.
BiLL77 is offline
Old 10-18-2015, 04:21 PM
  #19342
thanks lads, will run it, if i have dramas ill shim it up a mm.
Gavel is offline
Old 10-19-2015, 11:38 PM
  #19343
You know what, you won't have any drama's with the 34mm until 6 months down the track where your winning the best race you've ever had and boom it catches a rock and flames out.
Honestly mate, prevention is always better than the cure. I always look for potential race enders and do my best to remove them.
Soapy is offline
Old 10-19-2015, 11:55 PM
  #19344
am
Best post i have ever read on RCTECH!!! This is how i think too :-)
I use MP7.5 K3 enigne mounts and a 32mm flywheel. My clutchbell do not hit the chassis. And i use longer scrwesfor the plates that atatch enignemounts to chassi. I also use a nut ontop to sequre the screws.
Last edited by am; 10-19-2015 at 11:58 PM. Reason: Spelling, and it is still not right..
am is offline
Old 10-20-2015, 03:53 AM
  #19345
WOW that would ruin a race day.
BiLL77 is offline
Old 10-20-2015, 08:08 AM
  #19346
dameetz's Avatar
Can I use IFW458 with my original out of box front arm instead of IS119-41 that I have been reading to strengthen the front arm when using alum hub?
dameetz is offline
Old 10-20-2015, 08:48 AM
  #19347
Trader Rating: 25 (100%+)
That's exactly what ended Tebo's chances of winning the Worlds in Thailand, not sure if he had a 34mm flywheel fitted but whatever he had hit a rock in the double single section. I saw it happen right in front of me.
smelly62 is offline
Old 10-20-2015, 11:07 AM
  #19348
dameetz, Yes you can use the Hard Front Lower Sus. Shaft(IFW458) with the regular front arms(IF427B). You'll just need to ream out the captured hole a little in the back of the arm, so that IFW458 can pass through. As info, part#IS119-41 is the rear outer hingepin. Hope that helps.
Old 10-20-2015, 04:13 PM
  #19349
dameetz's Avatar
Thanks for the info dude.
dameetz is offline
Old 10-21-2015, 12:39 PM
  #19350
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
I don't know if this has been discussed, but has anyone tried the RS chassis? Curious to know if it allows for more flex on bumpy tracks, or if perhaps it tweaks faster?
1/8 IC Fan is offline
