Inferno MP9 thread
Okay can somebody share the secret in making the brakes work ? Seems like I have adjusted everything an I can not seem to get good brakes . It stops but if you give the car a push with the brakes on it feels grabby but doesn't lock in and stop the car . First day out with the car just trying to have it ready for Sunday's race . Thanks
Further assuming your brakes are measured and adjusted correctly.
It's wierd what you guys mention re: brakes and brakes grabbing. In approx 4 years of running MP9's I've never had any issues with either the kit black rotors or the slotted style.
As has been mentioned, make sure your EPA for brake direction is set correctly and also the exact rotor/pad measurement as per instruction manual. I've tried using the little springs between pads but found no noticeable improvement. Also tried fuel tubing instead of springs on brake levers but maybe I'm just not able to feel difference while on track so gone back to using stock springs and black rotors. Find they're somehow smoother and more controllable than the slotted rotors. Also I take some time to be sure the springs and stoppers are at exact position on the brake levers to be sure that the brakes engage within about 1.0-1.5mm of movement.
After setting everything as mentioned even when pushing car with hand on brakes full, no probs getting them to lock solid. Only prob I've ever had has been the car not stopping straight, as in when stopping from very high speeds to very slow, often my car will get crossed up but strangely this always happens to the right, never left. But as far as stopping power, no probs to get brakes to lock up. I'm using 7950 servo which has 35kg/486oz torque and that probably helps but just take the time to get everything exactly as per instruction manual and you guys should be ok or at least better as far as getting brakes to lockup. Hopefully...
R/C Tech Elite Member
I brought that issue up a long time ago. I tried everything under the sun tofix the grabbiness assuming we're taking about the same thing. .. I.e. it feels like the rotors are warped? I sanded, grinded, replaced, cleaned, adjusted, bed new brakes in and eventually switched to fiberglass. I've come to the conclusion that's how those brakes are. Oddly, on track you can't tell. Pushing the car with your foot and the brake on, you can tell.
Is the there a new mp9 in the works? I've seen a bunch of them for sale latley so I was just wondering. I've been thinking about picking up one and switching from the rc8.2, but I don't want to buy one and a new car come out in a few months.
Good observation, but just odd that it wouldn't do the same under acceleration like a fwd car does as well.
So using the abs, do you then set your epa to full lock the car and then turn abs on?
You have point about the car torque steering under excelleration. I'll have to do some research on that, it was just an idea. As for the abs I set my EPA for full brake and then adjust ABS. The key is to get the ABS cycling set so the car doesn't shutter under braking. Also there is a delay setting for the ABS which I have set so the ABS doesn't come on as soon as you hit the brakes I have it set to come on about a second after applying the brake
This is the time of year when most will switch sponsors if they are going to, so it seems like you'll always see more of each brand on here for about a month or two when that happens.
That's all I know, which isn't much...lol.
Brad
Why would you want to lock up the brakes and ultimately have the tires lose controlled contact with the dirt? I think that the objective to braking with off-road is to slow the car down, just like a full scale vehicle. Proper mechanical adjustments, brake bias and brake pad screw adjustments are critical. The latter, brake pad screw measurements, must be the same or else you'll have a delayed brake feel/effect. Just my 2 cents.
Assuming all brake adjustments being equal and correct, I do like the slotted discs better than the stock ones. The slotted discs provide stronger, more consistent braking. More consistent over time in long mains, and I can feel the difference in braking power consistency when I simply test the brake strength by holding one wheel and spinning the opposing wheel.
Torque steer in FWD is because the engine was placed parallel to the axles (and not longitudinal like most RWD and AWD/4WD). The front driveshafts are therefore unequal in length and them spinning up causes the car to steer.
I use the ABS function on my radio, also with a delay set so it doesn't kick in instantly. And as mentioned above, brakes are not an on/off switch, just like throttle is progressive and one doesn't need to pull the trigger to WOT every time they accelerate, same goes for braking.
An interesting discussion though.
