Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-12-2015, 09:16 AM
  #18466
Winner's Circle's Avatar
Originally Posted by Gixer Jay
That's what I was wondering about with the vented bells. I like the idea of shoe debris being able to get out and cooler air getting in, but along with the cooler air comes the dirt & tiny rocks. It may just depend on the track and the type of dirt surface.
I have been running the vented Kyosho bells for a while on my Buku and I have not had any problems with dirt of debris getting into the clutch. I have run in mud and extremely dusty conditions with it.
Winner's Circle is offline
Old 02-12-2015, 11:53 AM
  #18467
Will Kyosho be releasing an updated car soon ?
Eastside777 is offline
Old 02-12-2015, 12:13 PM
  #18468
sn47som1's Avatar
^^^ seriously
sn47som1 is offline
Old 02-12-2015, 12:31 PM
  #18469
^^^ Just a question mate.
Old 02-12-2015, 01:28 PM
  #18470
sn47som1's Avatar
You didnt get it "mate", was just referring
in other words, good question
sn47som1 is offline
Old 02-12-2015, 04:30 PM
  #18471
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Haven't heard of a new car coming out, but the local hobby shop did mention that Kyosho cars are going to drop in price. Local hobby shop has the tki3 for about a $100 less as well.
SEF is offline
Old 02-12-2015, 04:33 PM
  #18472
Trader Rating: 47 (98%+)
that sucks for me I just got one. Good for everyone else.
wichitafc98 is offline
Old 02-12-2015, 06:30 PM
  #18473
Default mp9 nose dives when jumping
I just got done building my tki3 and it really handles awsome. But I'm having problems with jumping. The rear end pops up when I hit even small jumps. I've had two mp7.5s and they both flew like a bird. I have the stock set up from the instructions with stock light blue springs. Can any one here give me any ideas on what I need to change
max92804 is offline
Old 02-12-2015, 07:00 PM
  #18474
Gixer Jay's Avatar
No.. The new RTR MP9's were just announced for release and they are not even available yet. With that said too Kanai also posted pictures today on Facebook of another batch of Spec-A MP9's that he was working on.
New buggy, nope not for a long while. Maybe some more updates or options though for the current MP9
Gixer Jay is offline
Old 02-13-2015, 02:40 AM
  #18475
check your ride height. If the rear end is low, that can happen. Try putting the rear at 30mm. While you're at it check the front too LoL
Make sure you have the appropriate oil in the shocks for the conditions.
Make sure your car doesn't have any drag on the brakes when the trigger is at neutral.
My ST-RR EVO is offline
Old 02-13-2015, 05:24 AM
  #18476
My bad "mate".
Old 02-13-2015, 06:19 AM
  #18477
The price reduction is more than likely Kyosho taking advantage of the favorable yen/dollar to decrease their cost disadvantage.
In terms of wing high flight... it is more than likely a little bit of drag in your drivetrain. Brakes, bearings, anything that can cause the wheels to stop rotating when you let off the throttle will make it do this.
I had this happen to me one weekend, and I actually really enjoyed how the car drove. I'm accustomed to running drag brake on my 1/10th scale cars. I took it out after I figured out what was going on because I was afraid of what it could do to my runtime.
phillypete is offline
Old 02-13-2015, 06:54 AM
  #18478
I have checked my brakes and drive train and both are perfect. That was what I thought it was at first. Ride hight is 30mm rear and 28mm front. Could it be that I'm running a shock oil that's to thick or thin. Right now I'm using 250 in the rear shocks and 350 in the front shock with the stock piston. I have a 2mm spacer under the rear piston and 1mm under the front piston to set the droop.
max92804 is offline
Old 02-13-2015, 07:00 AM
  #18479
I may have the oils weights reversed, it early and I need more coffee. Lol
max92804 is offline
Old 02-13-2015, 11:02 AM
  #18480
Your shock oil is way too thin ( I don't even use that low with my RB6 1/10 )
400 rear
550 front
This would be a good starting point with the kit pistons.
The 2mm spacer goes in the front shocks and the 1mm in the rear.
hipster is offline
