Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-05-2015, 12:29 PM
  #18406
sn47som1's Avatar
A little off topic, but how are we all tuning our engines. Do we start with the low end and idol or the high speed? Do we tune for the engine to idol all day or load up after a minute?
sn47som1 is offline
Old 02-05-2015, 03:51 PM
  #18407
coneman's Avatar
Originally Posted by LosiPRRACER
Just finishing up a new TKI3, is everyone starting out with either the 2010 WC or the CK loose setup these days? or is there a new good base setup?
try the kit stock setup first.
coneman is offline
Old 02-05-2015, 07:40 PM
  #18408
Trader Rating: 17 (100%+)
http://www.rctech.net/forum/offroad-...ing-bible.html
jaron_cc is offline
Old 02-05-2015, 07:57 PM
  #18409
sn47som1's Avatar
weeeeeeeeeell thats one way
some responses would take the cake tho
sn47som1 is offline
Old 02-05-2015, 11:49 PM
  #18410
Trader Rating: 65 (100%+)
Question: i know the kit shock bodies the anodizing wears fast. I was told if you buy the shock bodies seperate that the anodizing is much better. Im curious to know if this is true? Lastly, if this is the case, is the anodizing also different if you buy the complete shock set or just the shock body?
Thanks in advance.
nrm1977 is offline
Old 02-06-2015, 04:45 AM
  #18411
rfleck's Avatar
Trader Rating: 58 (100%+)
Thanks in advance.
I believe the only way to get the hard ano shock bodies is to buy them separately. I've had a set for over a year and they still look good.
rfleck is offline
Old 02-06-2015, 04:55 AM
  #18412
Moderator
WYLDTHING's Avatar
Trader Rating: 159 (99%+)
Thanks in advance.
Yes it is true, it is 100 times better than the anodizing (more like spray paint) they put on the kit shocks. And yes, you get the better anodizing either way you buy them (complete or just bodies), at least I have.
As much as I love this buggy, and I REALLY do (best buggy I have ever driven), this will be the main reason I leave it. It gets really old to spend that much more on a kit, and then have to spend several hundred more dollars to get a real hard ano chassis, shocks, towers, etc... Basically, all the stuff that comes standard on others kits, for a lesser price.
Hope the info helps.
Brad
WYLDTHING is offline
Old 02-06-2015, 05:31 AM
  #18413
sn47som1's Avatar
Sux, but just spend the money and have the best buggy on the planet tough as nails.
sn47som1 is offline
Old 02-06-2015, 05:39 AM
  #18414
tobamiester's Avatar
Trader Rating: 360 (100%+)
Never regret the investment. Buggy is dialed. All cars had drawbacks..Anodizing don't affect handling..Like alot of folks say on here, drop it on most tracks and its 90%+ there. Minor adjustments and it rocks...
tobamiester is offline
Old 02-06-2015, 05:54 AM
  #18415
Moderator
WYLDTHING's Avatar
Yes sir, I couldn't agree more! Just frustrating to me. While anodizing doesn't affect performance, it does affect maintenance costs. Not sure what I'm gonna do yet, but my wallet is screaming uncle...lol.
Awesome buggy though! Like I said, best I've ever driven, and I've owned or driven them all, except HB and Agama.
Old 02-06-2015, 06:03 AM
  #18416
Moderator
WYLDTHING's Avatar
There is a wealth of info in the nitro engine forum that will get you what you need as well. Engine tuning is kind of off-topic for this thread, so you may not get many responses on that one.
Brad
Old 02-06-2015, 06:42 AM
  #18417
sn47som1's Avatar
Sure, but exceptions can be made on a thread thats already got 1228 pages! :0 I think we got it
The tuning bible is best practice. I think Ill be trying out the Fioroni center diff mount. Talk about takin a hit to the wallet!! I think its $130 just for a mount! You could buy a used ofna kit for that LOL
sn47som1 is offline
Old 02-06-2015, 06:45 AM
  #18418
Trader Rating: 47 (98%+)
yah, that is kinda expensive
http://www.absolutehobbyz.com/produc...oducts_id=7694
I think I will wait a little while.
wichitafc98 is offline
Old 02-06-2015, 06:47 AM
  #18419
Moderator
WYLDTHING's Avatar
Sometimes yes. Sometimes it gets deleted if it's off-topic, and the question(s) is already answered if you just look in the correct forum.
Old 02-06-2015, 06:48 AM
  #18420
sn47som1's Avatar
Okay okay more on topic...
How do I connect the VP Pro battery switch, more so how are you guys installing and routing on the car? Does 1 end go into the batter box for a connection (or outside the box) and 1 end into the receiver?
sn47som1 is offline
