Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-04-2015, 06:29 AM
  #18391
sn47som1's Avatar
It is a Novarossi modified to JP specs, and then I went and got it modified some more and a ceramic rear :0! hahahahahaha man o man. Yes the mount is Fioroni and it is such a sweet piece. I can't believe I have to get her dirty LOL
sn47som1 is offline
Old 02-04-2015, 06:33 AM
  #18392
Trader Rating: 47 (98%+)
yes she is to pretty get her dirty.
wichitafc98 is offline
Old 02-04-2015, 06:44 AM
  #18393
sn47som1's Avatar
Maybe you guys could help me with this. Do any of you have an issue with when tightening the front upper suspension block just about snug the way it should be, the upper arms tighten up and lose their freeness. I HATE this. So to free up the arms I have to loosen the suspension block to a point where there is a little bit of wobble of the block. Is this okay?
sn47som1 is offline
Old 02-04-2015, 09:32 AM
  #18394
Trader Rating: 16 (100%+)
Originally Posted by coky barber
Tki3 servo tray fits the tki1???? Any help thanks...
Yes
aaron125 is offline
Old 02-04-2015, 11:31 AM
  #18395
Default M2C 2576 DELRIN CENTER DIFF REPLACEMENT BUSHINGS
GUYS,
There is some confusion the Amain wording of this replacement bushing
This bushing will fit both stock STRR AND THE MP9 TOP PLATES.
It also fits our split center diff mount (part no. m2c 2575)
the part no. 2776 center diff bushing is made for our m2c part no. m2c 2775
and is NOT A replacement for the stock mp9 top plate.
I have contacted AMAIN to correct the problem.
sorry for the confusion on this.
m2cracing is offline
Old 02-04-2015, 01:07 PM
  #18396
Something isn't right there. Make sure you have the you're arms orientated correctly. The "k" should be facing up and obviously l/r on the correct sides. Make sure the little clips are spaced correctly taking into account the caster insert in the hub and kickup angle and roll center (6,9, h, l) bushings. The setting guide should guide you. If you already have done all that, sometimes there is just a tad of flashing on the upper arm where the pin goes through. Also keep in mind the little clips are different widths so you gotta make sure you're not putting a 2mm clip in when you should have put a 1 mm one in. You can also cycle the suspension with out clips and see where the upper arms settle and use your best judgment on where to put the clips. The only thing they do is act as spacers. Lastly, a fair amount of slop develops there so it'll be free in no time. The suspension block should not be loose.
My ST-RR EVO is offline
Old 02-04-2015, 01:13 PM
  #18397
sn47som1's Avatar
what I was afraid of, I knew they had to be snug, if thats so, then I know for sure the left upper arm will be way to tight wont even move, the right wont be as tight but still too tight. hmmmmmmm everything is installed correctly upper and lower arms, the bushings are in all the way. Why cant they just make the plastics fit better from the factory. its really not that hard
sn47som1 is offline
Old 02-04-2015, 01:18 PM
  #18398
sn47som1's Avatar
Originally Posted by m2cracing
GUYS,
Awesome! thanks for the update. What will the aluminum center diff mount do for chasses characterstics and flex/handling? Will it change these characteristics at all?
sn47som1 is offline
Old 02-04-2015, 02:05 PM
  #18399
Smile CHASSIS CHARASTICS
To my knowledge, it does not change the charastics of the chassis.
but it makes it really easy to service. I have had a lot of guys tell me
that , just because it is so hard to get the diff in and out that they avoid
servicing the diff as much as possible.
and to do a diff change at a club race when you only got 40 or 50 guys
and the programs are running fast, they couldn't do it in time, especially
if they were running multiple classes.
now it is a 10 minute change.
Old 02-04-2015, 06:03 PM
  #18400
Winner's Circle's Avatar
I am running the M2C center diff mount and it had no effect on handling.
I love the fact that I can pull the center diff, change the fluid and have it back together very quickly. Because servicing the center diff is so easy I find that I experiment with different fluid weights much more frequently than in the past and as a result my truck is working better than ever now.
Lee
Winner's Circle is offline
Old 02-04-2015, 09:02 PM
  #18401
LosiPRRACER's Avatar
Just finishing up a new TKI3, is everyone starting out with either the 2010 WC or the CK loose setup these days? or is there a new good base setup?
LosiPRRACER is offline
Old 02-04-2015, 09:04 PM
  #18402
Lee
Do you have picture have your center diff mount? Or anyone have pics?
Old 02-05-2015, 11:36 AM
  #18403
sn47som1's Avatar
How much heavier is the mount than stock?
sn47som1 is offline
Old 02-05-2015, 11:42 AM
  #18404
I think the weight is a wash. By the look of the mount I think they have a little less metal the stock mount. I think value would be in the design.
Old 02-05-2015, 12:27 PM
  #18405
sn47som1's Avatar
I meant Id hope it wouldnt add weight but a lot of times aluminum adds a little bit no biggie.
sn47som1 is offline
