Inferno MP9 thread
I am making the switch from TLR to kyosho (now looking at a brand new 3.0 roller I won't use). I bought a very clean TKI3 with tons of spares from another member. I am wanting to do the D812 arm conversion on the TKI3. The rear arm should be a simple swap. However, does anyone know if the kyosho knuckles and spindles will work on the D812 arms? What about CVD length?
Any info would be greatly appreciated.
Idk man when I first bought mine everyone that didn't own an mp9 warned me about how they brake a arms so easy but the only thing I broke twice was the inner streering rod ends never broke an A arm
Unless you race in really cold temps and drive way over your head, the arms don't break. I wouldn't call them fragile. You can always boil them.
I would also soak them in plexus for a few days. Never broke an arm after doing that. That may be an option if I break arms on the TKI.
Sooo hookem and spads you here what happen to me?
R/C Tech Elite Member
Karma...
Okay Mark, let's hear it, what happened?
Back to the MP9 topic....
Drove my MP9e for the first time this weekend. I need more turn in entering the turns. I need more off power steering. On power steering is awesome.
Diffs 5-5-3
Sway Bar 2.3F 2.5R
Caster is 11degree with bushings
shock 1.3x8 Fr42.5 Rear27.5
Lt Blue spring Front and rear
I was thinking about going to 9degree caster but I haven't seen a setup sheet yet with someone using 9degree. Also thinking 3-5-3 on the diffs. Has anyone else had a problem with off power steering?
Diffs 5-5-3
Sway Bar 2.3F 2.5R
Whats your rear caber link position?
I will try less caster... use the c-hub bushing in the lower position... that help me alot. .. Check your ride height 28-30 should be a good starting point
Also Check your epa ... put the car on the ground and set it up
Diffs 5-5-3
Sway Bar 2.3F 2.5R
Diffs 5-5-3
Sway Bar 2.3F 2.5R
rear camber link is inside on tower 4th hole down and top inside hole on hub 9-4
I usually check epa on a stand and the servo saver is almost locked
