Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 10-06-2014, 01:34 AM
  #17881
Trader Rating: 16 (100%+)
Originally Posted by CnR
This ever happen to anyone ? Brand new shocks useless.
Just curious, what exactly is the problem with your shocks?
aaron125 is offline
Old 10-06-2014, 01:55 AM
  #17882
HomicidalBunny's Avatar
It looks like the top few threads for the shock cap for the shock body on the right have snapped off.. How that happened is the other question
HomicidalBunny is offline
Old 10-06-2014, 02:12 AM
  #17883
Wow!! Thanks for pointing that out, very strange indeed.
aaron125 is offline
Old 10-06-2014, 07:04 AM
  #17884
CnR
CnR's Avatar
Trader Rating: 31 (100%+)
That's how it came. Its a brand new set. I didn't notice till I went to put the shock cap on and it bottom out and continuously bleed. the piston would hit the bladder. the shock body looks clean cut so it doesn't look like anything broke off.
CnR is offline
Old 10-06-2014, 07:17 AM
  #17885
Infuriating That's lots of time and shock oil wasted. Time for an RMA!
Old 10-06-2014, 07:19 AM
  #17886
CnR
CnR's Avatar
RMA ?
CnR is offline
Old 10-06-2014, 07:49 AM
  #17887
houston's Avatar
Trader Rating: 96 (100%+)
RMA ?
Email [email protected]
If that dont solve it i will send you a shock body of my own CnR
houston is offline
Old 10-06-2014, 07:50 AM
  #17888
CnR
CnR's Avatar
Thumbs up
I emailed him this morning. Crossing my fingers. Thanks very much for the help.
CnR is offline
  #17889
dear Lord, that is awful! Next time you'll get a D812
Eivind E is offline
Old 10-06-2014, 12:38 PM
  #17890
houston's Avatar
Fyi ,joe is gone til next monday
houston is offline
Old 10-06-2014, 02:54 PM
  #17891
CnR
CnR's Avatar
I submitted a ticket on the Kyosho site so see how it goes.
CnR is offline
Old 10-06-2014, 03:56 PM
  #17892
houston's Avatar
I have never personally had any shock bodies with that issue , thats not good
Like i said if i have to send you a shock body i will
Is this out of a full kit?
houston is offline
Old 10-06-2014, 03:57 PM
  #17893
AZRC4Me's Avatar
Be sure you're dealing with Kyosho America if you're in the US:
Kyosho America Contact Info
From that photo it just looks like one of the shock bodies didn't get trimmed properly on the top. Frustrating if building a new kit for sure. KA will get you fixed up.
AZRC4Me is offline
Old 10-06-2014, 06:03 PM
  #17894
Trader Rating: 75 (100%+)
What other brands of clutch shoes can you run with the stock flywheel? Dynamite max life?
gixxer420 is offline
Old 10-06-2014, 07:57 PM
  #17895
coneman's Avatar
i'm using these on my truggy. stock flywheel. two club days and the shoes have no feathering, no need to remove and file the edges. should last a long time.
http://m2cracing.com/product.sc?prod...&categoryId=70
coneman is offline
