Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 01-11-2014, 03:01 AM
  #16261
Originally Posted by Drip View Post
Yuichi kanai the designer of the kyosho inferno mp9 tki3 is using one and has designed one that looks just like the plastic one. It is to increase feel and response of the throttle and brake.
you can use mugen cnc horn for throttle and brake
arivandy01 is offline
Old 01-11-2014, 05:17 AM
  #16262
Trader Rating: 6 (88%+)
no way jose i will never put a mugen part on my k car!!!
Drip is offline
Old 01-11-2014, 07:17 AM
  #16263
Trader Rating: 25 (100%+)
Amen to that, I'm proud to say that there are no other brand parts on my car except the engine and electrics packages of course.
I have my car here next to me to make sure that statement is correct lol..........yep it is.
Damn I just realised there is Losi shock oil in the shocks lol
smelly62 is offline
Old 01-11-2014, 10:24 AM
  #16264
GUILTY!!!!! LOL
Drip is offline
Old 01-11-2014, 03:31 PM
  #16265
Quick question regarding the front brake cam. Are you suppose to cut the plastic bridge between the front half top differential housing (Part #: IF405)? The rear cam fits nice in the plastic "C" position of the bridge. The front sits lower and is to short to fit into this "C". The instructions say no where to cut the portion out??
RiPPeN302 is offline
Old 01-11-2014, 06:03 PM
  #16266
if you mean this part, yes remove and that goes for both front and rear.
bohdi is offline
Old 01-12-2014, 07:26 AM
  #16267
K_King's Avatar
Trader Rating: 43 (100%+)
Hey guys is there a list of parts I would need from my MP9e TKI to turn into the Nitro version? Curious at what it entails.
K_King is offline
Old 01-12-2014, 09:24 AM
  #16268
Trader Rating: 75 (100%+)
Tank, radio tray, battery boxes, clutch, clutch bell, exhaust holder, throttle linkage, air filter assembly, brakes
gixxer420 is offline
Old 01-12-2014, 09:26 AM
  #16269
BMenard17's Avatar
Trader Rating: 88 (99%+)
Brakes
BMenard17 is offline
Old 01-12-2014, 09:39 AM
  #16270
Trader Rating: 42 (98%+)
King stepping up with the big boys
RockStar_199 is offline
Old 01-12-2014, 10:13 AM
  #16271
K_King's Avatar
Originally Posted by BMenard17 View Post
Brakes
Motor mount also?
hehe sup Mark
K_King is offline
Old 01-12-2014, 10:25 AM
  #16272
BMenard17's Avatar
Receiver pack
Old 01-12-2014, 12:21 PM
  #16273
fuel tube and fuel filter
bohdi is offline
Old 01-12-2014, 12:27 PM
  #16274
Winner's Circle's Avatar
Maybe you can find someone with a nitro MP9 that is converting it to electric and pick-up the nitro parts from them.
Lee
Winner's Circle is offline
Old 01-12-2014, 05:41 PM
  #16275
I would get the M2C motor mount , and M2C is still running the 25% off till the end of the month.
If you want a aluminum throttle servo horn , look at the Hudy V2 offset , Absolute Hobbyz has them , that's what I use
rcnard is offline
