Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 01-04-2014, 04:13 PM
  #16246
Do you have a rough release date and part #?
Originally Posted by Drip View Post
There is one being released by kyosho and will be available shortly
RiPPeN302 is offline
Old 01-04-2014, 04:39 PM
  #16247
Trader Rating: 6 (88%+)
Not an exact date but very soon. I would hold off until the release the plastic one will work perfectly until then.
Drip is offline
Old 01-05-2014, 04:15 PM
  #16248
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Had a question about bump steer. None of the setup sheets mention that. How to get rid of it? I tried adding washers but my hudy system still showed steering changes on compression and rebound. Any set methods for such and such caster spacers under plate and over steering knuckle?
Also the aluminum plate and the steering arms (servo saver and the plastic one) are a bit sloppy. I built the rack with the provided spacers, do I need to add more of my own?
aloksatoor is offline
Old 01-06-2014, 05:19 AM
  #16249
You can't get rid of it on 1/8th buggies. You can minimize it though, I recommend spacing the Ackerman bar up giving less bump steer getting into corners.
30Tooth is offline
Old 01-06-2014, 10:12 AM
  #16250
aloksatoor's Avatar
I have gotten rid of it on my tekno sct 410 and the xb9 before. It was late and was racing the next day so could not experiment. I drove it without the spacers and it seems way better than my xb9 ever did hahah. So you are saying put spacers under the ackerman plate where the track rod attaches? Or somewhere else?
My basic understanding was to try to make the track rod parallel to the lower arm so it does not push or pull the wheel through the suspensions full motion.
Old 01-06-2014, 01:58 PM
  #16251
I have done this on my old D8 before when it had bump out. The car felt much better after getting it to neutral. On the MP9, I don't see much bump steer overall, not enough to warrant an adjustment.
inpuressa is offline
Old 01-06-2014, 02:14 PM
  #16252
aloksatoor's Avatar
Ok I will recheck my front setup again. Because I must have missed something, mines giving a lot of bump steer on compression.
Old 01-06-2014, 04:47 PM
  #16253
Trader Rating: 16 (100%+)
Originally Posted by RiPPeN302 View Post
Who is using an aluminum throttle/brake servo horn? Kyosho makes one for steering, but I cannot find one for throttle/brake. Would like to find 2 that match.
It is for a Ko Propo servo.
Why would you want to use a metal servo horn for the brakes/throttle? Never seen any top pros using them, and definitely no one from the factory sponsored Kyosho teams in the US or Australia uses metal horns for brakes/throttle. It just isn't needed whatsoever. Cody didn't use one to win his WC and Tebo also had the plastic servo horn at that race too.
Something to think about before you go looking for a part which really isn't needed. Just my 2cents worth.
aaron125 is offline
Old 01-06-2014, 04:59 PM
  #16254
Yuichi kanai the designer of the kyosho inferno mp9 tki3 is using one and has designed one that looks just like the plastic one. It is to increase feel and response of the throttle and brake.
Drip is offline
Old 01-07-2014, 04:38 AM
  #16255
Not under where the rod attaches to the plate, it's where the plate attaches to the servo saver arm, so you are spacing the plate up. This adjustment is easier on 2wd buggies and TC sedans because they're designed to be adjustable that's what I meant
While we're at it, should the steering linkage be parallel to the ground or the arm?
30Tooth is offline
Old 01-08-2014, 07:59 PM
  #16256
Guest
I need help! I have a set of white tapered pistons out of a box stock tki3. Does anyone know what they are??
kyoshoracer77 is offline
Old 01-08-2014, 08:17 PM
  #16257
Guest
D post
Old 01-08-2014, 11:12 PM
  #16258
ben73's Avatar
Trader Rating: 40 (100%+)
1.4mm x 8 hole
ben73 is offline
Old 01-09-2014, 04:53 AM
  #16259
BMenard17's Avatar
Trader Rating: 88 (99%+)
If they are straight hole then they are most likely 1.3x8. Check the manual for a part number but I just built a mp9e and it came with the 1.3x8
BMenard17 is offline
Old 01-11-2014, 02:51 AM
  #16260
simon0721's Avatar
Default New kyosho readyset
After the MP9 TKI 3 readyset, Kyosho is about to release also the MP9e TKI readyset. Part no. 30877T1. I think it will be avaiable soon.
simon0721 is offline
