Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 11-21-2013, 05:13 PM
  #15871
Trader Rating: 75 (100%+)
Originally Posted by SEF
Are you using these shock bladders?
http://www.amainhobbies.com/product_...ck-Diaphragm-4
If not, these are a must. Much better feel and durability than what comes stock on the tki3.
The stock ones arent that good
gixxer420 is offline
Old 11-21-2013, 05:15 PM
  #15872
BMenard17's Avatar
Trader Rating: 88 (99%+)
Originally Posted by killabud
I had the csi bladders and found they were a little thick and get squished and make the caps not fit well. Went to the bladders mentioned above and haven't looked back.
I see what your saying.. I'll try them before I hate em lol
BMenard17 is offline
Old 11-21-2013, 07:24 PM
  #15873
Trader Rating: 14 (100%+)
anyone know if there to be an updated kyosho mp9 coming soon?
for next year maybe? tki4 ?
bluexile67 is offline
Old 11-21-2013, 07:25 PM
  #15874
Nope
Old 11-21-2013, 07:32 PM
  #15875
BMenard17's Avatar
Originally Posted by gixxer420
Nope
How do you know?? Or is it you just hope not cause you got $3000 worth of spares lol
Old 11-21-2013, 07:36 PM
  #15876
Read back in the thread its been asked and answered. If they did it would be updates here and there. Not a totally chassis update. Why change what has been working for years.
Old 11-21-2013, 07:49 PM
  #15877
if they do, my only beef is the weight but I am not going to spend money to make it lighter.
bohdi is offline
Old 11-21-2013, 08:01 PM
  #15878
Has anyone ever thought about powder coating the aluminum on these buggies? Thats the only think I hate is how it wears. You can build a new kit and put a months of racing on it and the buggy looks half season old. Just a thought not sure even if it could be done or the cost.
Old 11-21-2013, 09:36 PM
  #15879
Trader Rating: 24 (100%+)
I have a question about tire wear.
I noticed that Tebo's car came off the track after the C-netic race with the front tires practically slicked and still some tread left on the rears. I was wondering what was the reason for the front tires wearing faster than the rears?
Thanks in advance!
Hollywood_26 is offline
Old 11-21-2013, 09:57 PM
  #15880
Thanks in advance!
I would venture to say track conditions. There are some tracks we run on that will simply eat tires. Then the next time we race there tires are fine.
Old 11-21-2013, 10:03 PM
  #15881
Trader Rating: 28 (100%+)
Sean will be able to chime on this question for the fifth time...
big lou is offline
Old 11-21-2013, 10:14 PM
  #15882
Thanks in advance!
Probably the diff oil weights he was using.
TurboRabbit is offline
Old 11-21-2013, 10:21 PM
  #15883
The reason I ask is that with my current setup, I want to get a little more pull out of the front tires. I feel that the rears are overpowering the driveline causing an oversteer condition with the car to over rotate a little more than what I would like.
What changes could I make to get more drive and pull out of the front wheels?
Old 11-21-2013, 10:46 PM
  #15884
Guest
What oil do u have in the diffs now?? 5-5-3 front -center-rear??
kyoshoracer77 is offline
Old 11-21-2013, 11:45 PM
  #15885
Thanks in advance!
That would be thin oil center diff, and thicker front.
For example if he ran 6 or 7 in the front, 3 or 4 in the middle, and 2 in the rear, that would make his tyres wear a lot quicker in the front than in the rear.
Similarly, for the other question about getting more pull on the front, go thinner on centre diff, that should do the trick.
Eivind E is offline
