Inferno MP9 thread
The only MP9 which has ever been supplied with a HA chassis from the box was the original MP9 TKI. All other MP9 variations over the years have come with the dark brown anodized chassis. Absolutely no difference besides the anodic layer, the chassis themselves are identical.
havnt we been through this a million times... someone posted the HA version is like 0.19 thicker, people have said they have had a differnce between the chassis' (HA not flexing as much)
Use animal balloons. You get a 100 shock boots for the price of 6 Kyosho shock boots, and they work great. You can get them with your next bearing order through TKO here:
http://tkocompetitiondev.com/product...roducts_id=326
Here is what they look like installed:
http://www.rctech.net/forum/9663848-post2738.html
Lastly, I take an exacto knife and cut off the sharp corner in the shock end that tends to cut the shock boots. Just take a little off so there isn't a sharp corner, but enough to be able to seat the shock cup.
Get some great shock building tips here:
www.neobuggy.net/2013/07/01/shock-build-with-mike-cradockwww.neobuggy.net/2013/07/01/shock-build-with-mike-cradock
And you are correct too, the hard anno chassis does have different flex.
Rear Hub Spacers
Does anyone know if the rear hub spacers can be brought separately, or are they only part of the Rear Hub parts kit when you buy it?. Since these wear out I would hope that they can be purchased without having to buy a set of rear hubs. Any part numbers known are appreciated. Thanks.
For guys that are running the stock kyosho clutch, what setup do you use? Is the one that comes with the A spec good for medium to medium-low bite?
I think he's referring to the spacers used to adjust wheel base length. And those aren't sold separate! Think they are attached to the plastic rear hub tree.
Congrats to Tebo and Boots at neo 13!!!! And a shout out to Cody, for driving his butt off coming in 4th from 15th. Way to go guy's!
Anyone know if the universal pins that go into the outdrives are replaceable? My center universals are in good shape but the end pins are getting pretty flat. Surprisingly, the outdrives aren't that bad. Thanks.
