Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-07-2013, 06:04 AM
  #15121
I think there is a difference.
Awhile back I replaced a chassis and the drive was different to the old chassis.
Maybe that is why the TKI3 does not have a HA deck...
Mater is offline
Old 08-07-2013, 07:45 AM
  #15122
Hello
Anyone Know where I can get Silverstate 2011 King or Tebo setup..
Tanks
brnantunes is offline
Old 08-07-2013, 07:51 AM
  #15123
305M3's Avatar
Trader Rating: 43 (100%+)
Originally Posted by brnantunes
Hello
Tanks
I think has what you need:
http://www.kyoshoamerica.com/Factory-Setups_c_842.html
King's Silver State from 09 is here:
http://www.infernosonly.com/Download...heets_s/24.htm
305M3 is offline
Old 08-07-2013, 07:52 AM
  #15124
Afun's Avatar
Trader Rating: 19 (95%+)
Any word on the TKI4
Afun is offline
Old 08-07-2013, 08:10 AM
  #15125
Motorman007's Avatar
Trader Rating: 89 (100%+)
NO WAY really.
I was thinking the one that is out is good. What can make it better?
It looks good as is.
Motorman007 is offline
Old 08-07-2013, 03:23 PM
  #15126
killabud's Avatar
Hey guys, I have the aluminum servo saver arm on the way and want to know how much people are cranking down the spring when running it?
killabud is offline
Old 08-07-2013, 04:29 PM
  #15127
Originally Posted by 305M3
Tanks, but isnt that, I need one setup for a super bumpy track like silver state 2011, because I have run in a track like that but with more bumps, And I dont now what to do to make my car more stable, I run with a XB9 and the car is very stable.
Old 08-07-2013, 05:09 PM
  #15128
305M3's Avatar
Let me keep looking. I have them printed off, so I know I got them from somewhere... Worst case is I'll scan them in...
305M3 is offline
Old 08-07-2013, 08:29 PM
  #15129
Guest
Hey man try infernosonly.com .
kyoshoracer77 is offline
Old 08-07-2013, 11:46 PM
  #15130
corky_rc's Avatar
Ive got these installed on both my TKIE and TKI3, with about 5mm of thread showing, and it works fine.
corky_rc is offline
Old 08-08-2013, 02:16 AM
  #15131
Is this the agama mount people use to raise the motor a few mm higher?
http://www.amainhobbies.com/product_...-Top-Block-Set
thorns is offline
Old 08-08-2013, 03:06 AM
  #15132
Hello
What is the best piston and diaphagm for super bumpy condition?
Tanks
Old 08-08-2013, 03:34 AM
  #15133
killabud's Avatar
Sounds about right. Thanks!
killabud is offline
Old 08-08-2013, 04:16 AM
  #15134
yes but raises only 1mm
bohdi is offline
Old 08-08-2013, 07:08 AM
  #15135
jpz_67's Avatar
Trader Rating: 57 (100%+)
Hello
Tanks
I have tried several different piston/oil combos but always end up coming back to the 1.3 x 8 hole pistons. As for springs I can usually run blue front and orange rears on most track surfaces. Take a look at Cody Kings rough track set up, I believe he uses orange springs in the front and then yellow in the rear. I have yet to test this combination.
jpz_67 is offline
