Is this normal? - clutch bell discoloration. >
Old 05-13-2008, 08:56 PM
Default Is this normal? - clutch bell discoloration.
RC8
New 17T clutch bell
Impulse hard clutch shoes
AE 1.0 springs
The last time I raced 1/8 scale I used fiber clutch shoes. Alumnium had just come out, and I never used them. Is the clutch bell discoloration I am seeing normal for alumnium clutch shoes? I have about 2/3 gallon through the clutch and engine.
largeorangefont is offline
Old 05-13-2008, 09:00 PM
Powerlink's Avatar
Im thinking that this buggy is an rc8 , Mine does the same ,however not as severe, chassis flex can causes this . Not sure in your case though.
Powerlink is offline
Old 05-13-2008, 09:01 PM
ezveedub's Avatar
Trader Rating: 17 (100%+)
If your talking about the marks around the CB, thats from the bell hitting the chassis. Thats an RC8 chassis flex issue. Not sure if the KH extended mounts stop it.
ezveedub is offline
Old 05-13-2008, 09:04 PM
Originally Posted by Powerlink
Im thinking that this buggy is an rc8 , Mine does the same ,however not as severe, chassis flex causes this to the clutch bell..
Gotcha. That is what those wear marks on the chassis were when I bought it. I thought the previous owner had a clutch bell bearing go out or something.
Yes it is an RC8.
Old 05-13-2008, 09:08 PM
Powerlink's Avatar
Yes it is an RC8.
The RC8 is designed to flex alot so, some sacrifices in other areas of the car will suffer a little .I don't mind the marks , the car hooks..
Old 05-13-2008, 09:11 PM
I'm not worried about if that is the cause. I've had clutch bells turn bluish, but never silver so I was just wondering. Now it makes perfect sence.
Last weekend was my first time driving an RC car in 6 years, let alone on a track. The car is great so far, I cant wait to race it.
Old 05-13-2008, 09:22 PM
mblgjr's Avatar
Trader Rating: 86 (100%+)
Ashley is that you?
mblgjr is offline
Old 05-13-2008, 09:24 PM
Originally Posted by mblgjr
Ashley is that you?
Yes
Old 05-13-2008, 09:27 PM
mblgjr's Avatar
Well; glad to see you race in scale too...haha
I think they've answered it for you; but it appears the bell has been lightly rubbed on the outside.
If you've not really experimented with an aluminum clutch setup; just make sure you inspect it for wear every couple of race weekends at the most and stay on top of the bell bearings; as they tend to run a bit hotter.
-Matt.
mblgjr is offline
Old 05-13-2008, 09:33 PM
-Matt.
Thanks Matt.
Yea I am getting back into racing, but more for fun this time. Before I raced every class from 1/10 to 1/5, had a couple sponsors and was fairly deep into it. This time only 1 car in my favorite class. Do you race at all?
Old 05-13-2008, 09:35 PM
mblgjr's Avatar
Yeah; I run 1/8th buggy; 1/10 truck...been at it for about 19 years...haha.
mblgjr is offline
Old 05-13-2008, 09:47 PM
Do you run at Revelation? I need some guys to race with!
Old 05-14-2008, 12:02 AM
mblgjr's Avatar
Haha; not unless you fly me out to your side of the world.
I'm on the East coast basically. I run AL/E. GA/SE TN for the most part and do pretty limited traveling.
mblgjr is offline
Old 05-14-2008, 02:09 AM
fadedmindz's Avatar
Thumbs up
hey im barely starting to race 1/8 scale. i live in corona. i was planning to go to revelation. how often you go??
fadedmindz is offline
Old 05-14-2008, 06:26 AM
tex1's Avatar
Red face Have you considered??.........
You should pull the hardware out of the car and grind the matching spot on the chassis. The new Associated chassis are comming this way. Try the KH extended motor mount as well. It will help protect both of your gears and it will also save you on clutch bearings. This will keep you from using your kitchen passes for DNFs at the race track.
Hope this helps,
TEX
tex1 is offline
