-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   Engine problems (https://www.rctech.net/forum/nitro-off-road/217682-engine-problems.html)
cherokee 04-18-2008 07:24 AM
Engine problems
I have had an 1/8 buggy stored for about 8years...just sitting in my rafters in the bacement. I decided to get it down and the engine looked to be locked up. Turns out that the after run oil I put in had turned into goop that locked the engine tight. I removed the back cover and cleaned it out with brakekleen and carb cleaner, the engine turns fine now.
After a new glow plug the engine fires right up and idles great, works great till you get to about 1/4 throttle then it will die. Does not matter if there is a load on the engine or not. I did not clean the carb on the engine at all.
Any Ideas?
Vigilante212 04-18-2008 09:43 AM
I would clean the carb and replace any orings or gaskets on it. Also clean out the needle jets I bet they are all gummed up.
Fresh fuel also incase you tried using old stuff. :)
blktransam 04-18-2008 10:24 AM
make sure the air filter is clean and oiled. replace all the old fuel tubing make sure the fuel tank is as clean as new.... and of course disasemble the carb and replace and worn o rings
