newb question but can you drill holes in your fuel tank
Yes I have seen people do this to their tank. Make sure you drill a hole smaller than the fuel tubing you wish to insert. It's also a good idea to seal around the tubing with sealant that is fuel resistant.
yoo bro thats why he said make a small enough hole for the tube and put some sealant around it. a hole smaller than the tubing will provide sufficient enough pressure but sealant is and added bonus so there is no tuning issues.
CA Glue!!
dude dont drill a hole in you tank
I'm sorry I misread i thought you ment for a fuel pick up. Yes as others have said CA glue will work just fine. Sorry about leading you the wrong way. You can put holes in tanks as long as you seal them with fuel resistant sealant. I would go the CA route tho. You can also use some 3m clear double sided tape. The stuff is sticky as as anything, and won't stop the tank from flexing like a hard spot of CA.
