turbo or non turbo
Team magic M1B Turbo all the way!
non-turbo
- plugs are half the price
- not as finicky tuning
Turbo. Plugs last longer and tune better. Not to mention by the time you by two or three conical plugs, I'm still on my first Turbo plug.
I've blown 4 turbo plugs (C6 and C7, and two ultra C7 nova plugs) in less than half a gallon, as opposed to 1 std plug with the same amount of fuel. I would say Turbo engines are far more brutal to 'improper' needle settings
turbo because they have way more power...Plugs also last longer.
Another great thing about turbo plugs is that you don't have to worry about the washer that comes on standard plug.
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Can you switch between the two types of plugs on the same engine?
you will need the correct button head for the turbo and the non-turbo plug other then that you should be good to go
