Mugen MBX5T in the sand
will this car be ok in the sand???
what do i need to modify???
thank you
peter
thank you
peter
it will be fine.
you will possible need to replace bearings though. If i were you i would clean everything when you get done with simple green then WD40.
have fun!
have fun!
put paddle tyres on the rear, and yeh clean it very well, bearings, grub screws, and always check the spur is connecting with the clutch bell before you use it again, i have chewed 2, maybe 3 plastic spurs making the wrong decision, like yeah it worked yesterday when i turned it off it should be ready for another thrashing......umm...NO its not, one thing i have learnt it's dont be too eager to get the thing going, check, check, and check again
