Is the stock MBX5 kit still in production? >
Old 03-09-2008, 06:59 PM
Cannondale1974's Avatar
Trader Rating: 33 (100%+)
Default Is the stock MBX5 kit still in production?
Not talking about the "R" or Prospec but the original MBX5. I see A main has these for sale but no one else advertises this kit? Are these possibly left over kits they are liquidating or can other hobby shops still get these?
I'm heavily leaning towards this kit for $320 Love the R but don't want to pay almost double for my first season of club racing.
Thanks again guys.
Cannondale1974 is offline
Old 03-10-2008, 01:57 PM
Registered User
I doubt it the R took over the Prospect a while back not sure if they two versions of the R.
Loop&Roll is offline
Old 03-10-2008, 02:04 PM
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
You can still get them at amain hobbies $319.99
http://www.amainhobbies.com/product_...oducts_id/1817
thecman26 is offline
Old 03-10-2008, 02:09 PM
xlgraphicspro's Avatar
It's a Prospec not a Prospect. I'm thinking people say that just to bug me
Get the MBX5, it's a great deal for a great car. some people I know like it more than the 5R. plus you can upgrade to the 5R as your skill improves.
xlgraphicspro is offline
Old 03-10-2008, 05:05 PM
Correct me if im wrong but didnt the R version move the motor and radio tray location to center everything more. If I am wrong that means the only thing that is different on the R version is the prospec parts?
Jake
Bubonic-X is offline
Old 03-10-2008, 06:48 PM
Davidka's Avatar
Trader Rating: 86 (100%+)
The MBX5 and MBX5 Prospec are the same basic car, the Prospec has strength upgrades (thicker shock towers, CNC chassis braces, CNC alloy rear hubs and a one piece engine mount).
The MBX5R uses the same chassis (engine and radio locations) but has upgraded, longer shocks and revised shock towers and front arms to allow more travel and has all the Prospec level aluminum parts. Otherwise, the R is still very similar the the original MBX5.
Davidka is offline
Old 03-10-2008, 07:08 PM
slaytanic's Avatar
Trader Rating: 20 (95%+)
The R chassis is milled out in the front to allow for more droop that the shocks offer. The un R chassis can be easily modded to match it.
slaytanic is offline
Old 03-10-2008, 07:10 PM
slaytanic's Avatar
Alot of people with R's actually runt the original MBX5 plastic rear hubs and pivot ball type chassis braces that should say something.
Old 03-10-2008, 08:08 PM
Registered User
U can get the MBX5T Prospect but i didnt think u could still get the MBX5 Prospect...
Old 03-10-2008, 08:44 PM
ezveedub's Avatar
Trader Rating: 17 (100%+)
The R chassis only has has the front end milled out for droop. Other than that, the same layout. I compared it already. As for the MBX5 vs ProSpec, the prospec had thicker shock towers, solid braces, aluminum rear hubs, one piece motor mount, and other minor details.
ezveedub is offline
Old 03-10-2008, 09:44 PM
Thanks everyone for the replys, looks like the MBX5 may not be a bad way to go for the price.
Old 03-11-2008, 08:51 PM
thecman26's Avatar
Yeah, for the money its an excellent investment!!!
:t ire:
Old 03-12-2008, 07:08 AM
TonysScrews's Avatar
The MBX5 ProsPec and newer MBX5R kits also have more tuning options with the front kickup blocks (comes with a 0 block) and rear toe-in plates (comes with 2.25, 2.75 and the three -1 anti-squat toe-in blocks). The old MBX5 standard buggy kits may have the old front lower arms and front uprights. You can mod them for the extra steering or just replace with newer 5R parts. It does come with the old turnbuckle style chassis braces (which I run on my car) and the old servo-saver (which some like better than the new inverted one). The new 5R steering links are 4mm and well worth the upgrade over the old 3mm units. It also comes with the old brake linkage kit. You can get the 5R unit or just use a longer 2x12mm cap head and a plastic shim to raise the upper brake linkage so it is parallel with the bottom linkage.
If you or anyone else decides to get the old MBX5 kit, I have a set of Titanium tunrbuckles for it (standard kit comes with heavier steel units) plus a bunch of the old shock parts (rebuild kits, spare shafts, etc) I'm selling cheap if you want to carry some spares. I also have the optional white spring sets for the old shorter shocks.
Best regards,
TonysScrews is offline
