New XRAY 808
Old 06-30-2008, 05:08 PM
  #1396
xlgraphicspro's Avatar
Default fuel delivery issues?????
Well, I had a good race this past sunday. finished 4th in the A main, but I'm currently having an issue. I have alot of air bubbles in my fuel line, and I can't find the source. I replaced all the fuel lines, and also I replaced the o ring for the fule tank. It's causing me to flame out when a large air bubble reaches the carb. I only flame out when my fuel tank is opened for a pit stop. I can keep the rpm up to combat the air bubbles, but as soon as I'm back on the track, the engine acts really fat for about half a lap, then it's fine.
Can thr fuel tank have a crack along the seam? How do I check that, or could my pipe have issues and cause pressure to back up?
xlgraphicspro is offline
Old 06-30-2008, 05:27 PM
  #1397
mremtr's Avatar
Sounds like you have a tiny piece of crap in the main needle, or fuel nipple.check this area out first , and don't take the needle out of it's bore ,remove it from the carb as an assembly so you can see if there is anything in it .Then look down in the carb wear it came from and see if there is something in there. I had a hair like piece of plastic cause me all sorts of grief just like your taking about.
mremtr is offline
Old 06-30-2008, 05:28 PM
  #1398
ManicRC's Avatar
Trader Rating: 135 (100%+)
I've had a similar ongoing problem with my RC8. They had a bad run of tanks and I've ended up with four of them. The fuel pickup inside the tank had pinholes in it and it would introduce air in to the fuel line any time the tank wasn't completely full.
ManicRC is offline
Old 06-30-2008, 08:35 PM
  #1399
pumpkinfish's Avatar
Originally Posted by pablo101
I noticed you have a losi front air filter wire support....Can you take a pic of it installed?
I like how it stays away from the body plus it is secure from bouncing around.
pumpkinfish is offline
Old 06-30-2008, 08:50 PM
  #1400
Trader Rating: 80 (100%+)
What air filters do you recommend for a OS V Spec engine?
What after-run oil is recommended?
Do I need to get any kind of throttle or servo linkage parts that dont come in the kit?
My XB808 is currently waiting to be picked up at the post office!
Chirag
cpatel529 is offline
Old 06-30-2008, 09:26 PM
  #1401
I use the losi airfilter and boot aswell, but I also like to use the prefilter. Pumpkin, your living dangerously
Old 07-01-2008, 05:55 AM
  #1402
tex1's Avatar
Thumbs up Very nice...
I agree with XL here. I run the Losi air filter as well. Dry on the outside element and the real nasty red Mugen oil on the inside element. I run Outwears for real dusty outdoor tracks. I like that wire mod! I'm going to go that route as well.
This small filter keeps away from your body, fuel line routing and fuel filters as well. I never had a problem with them on the 8ight so I don't expect any here.
Good catch on that mounting wire!
TEX
tex1 is offline
Old 07-01-2008, 08:52 AM
  #1403
Trader Rating: 208 (100%+)
I look forward to my 808 build this week!!! Should be here tomorrow.
dodgeguy is offline
Old 07-01-2008, 12:15 PM
  #1404
rmargiotta's Avatar
Trader Rating: 59 (100%+)
Originally Posted by losi8lunie
Does anybody have any photos of there throttle setup with ACE 1015 servo as i cannot get mine right. The servo is quite tall and is about 1mm off the chassis (which i think is to close anyway) using the rubbers but the brake linkages are not parrallel to the servo horn and the connections to the brake cams.
when i try and set it it binds the brake cam arms and is sticking, the manual is no good either as it shows the arms set in different holes but i have tried all and nothing seems to work. The arms are perfect when they rest on top of the brake cams so it as if the servo is 2-3 mm to high but i can't lower it.
The photos i took haven't come out but i will try and get a better camera if needed
Cheers
Lunie
Sightly bend the lower mount up and it will fix everything, this is one thing I noticed when I built my proto-type car. I listed it in the XRAY forum, but again, this was a while back.
rmargiotta is offline
Old 07-01-2008, 12:24 PM
  #1405
rmargiotta's Avatar
My car was doing the same thing and bogging slightly on the bottom, so I was messing with this at work and this worked...
Unscrew the plastic piece that holds the o-ring in and sand/file the top of this piece down so it squeezes the tank o-ring more and makes it seal better.
Old 07-01-2008, 12:25 PM
  #1406
rmargiotta's Avatar
Good call! This is the first thing Kinwald did to his 808.
I just have too many of the Pro-Line air cleaners to throw them all away!
Old 07-01-2008, 12:44 PM
  #1407
First thing I did was unscrew the plastic piece that holds the o-ring in, but instead of what you did, I took plummers tape and wraped it around the plastic piece several times, then I put the O ring back on, so it would be pushed out a bit more, seemed to work for my qualifiers, but it started up again right before my a-main. I was lucky to keep it runn'n with throttle control. but after my pit and I got past the boggy feel, it was good untill the end of the race. I think I might buy a new tank, and experiment with the old one.
what is the best way to check tank pressure?
Old 07-01-2008, 12:45 PM
  #1408
I had too many of the losi airfilters just to throw away! that's how I arrived at that choice.
Old 07-01-2008, 03:19 PM
  #1409
This is right after a quick tear down and cleaning. I still have to change the inner air filter and re-oil the outer. If I put the outer on I'll forget to change the inner
I have been thinking about trying to fit an 8ight tank. I have always liked the "clunk" design and when I had my 8ight it saved me more than once with lazy marshalls. I know it is my fault I flipped, but I always marshall the way I want to be marshalled. Seems that isn't always the case.
Old 07-01-2008, 03:56 PM
  #1410
rmargiotta's Avatar
Get a bowl of water and attach CLEAN fuel tubing to the fuel and pressure nipples. Blow in one and block the other while submerging the tank.
Air bubbles - Bad
Blue face and popped ears - Good
Fuel tank clunk
Take out the internal fuel filter, unscrew and block the stock fuel nipple location. Drill a hole in the front of the tank and put this bad boy in there (attached to the fuel line, of course) and put an inline fuel filter on there. You should be good!
