New XRAY 808
Old 06-26-2008, 03:02 AM
  #1366
Z00M's Avatar
Trader Rating: 15 (100%+)
I ran the 5 x 12 and 13 x 19 bearings this past weekend and the bearings are great quality. Their service is awesome as well. The good thing is they have the bearings in stock!!!
Z00M is offline
Old 06-26-2008, 07:32 AM
  #1367
tex1's Avatar
Wink Why didn't you say you were calling the Wolf!!...
Rocco - Im picking up a red shell for your Halo today!!
I have not forgot about you. Had to get the parts together and my engineer is on vacation. Made it a little tuff.
I'll call you later.
Gary H. is loving his car!
TEX
<---- Not done yet!
tex1 is offline
Old 06-26-2008, 08:02 AM
  #1368
rmargiotta's Avatar
Trader Rating: 59 (100%+)
TEX
<---- Not done yet!
Right on man, no rush at all. I can't wait to get out there, haha, I'll be calling you when I do go!
If you need anything let me know, I'll be talking with ye.
-Rocco
Back on topic:
Make sure you back the 3 screws that hold the pinion gear out 1/4-1/2 a turn each to keep stress of these bearings!
rmargiotta is offline
Old 06-26-2008, 09:20 PM
  #1369
Djballen's Avatar
Originally Posted by rmargiotta
Back on topic:
The Supplementary Sheet said 1/12 a turn each? Like 1hr each. Do we need to loosen them that much? Like 3 to 6hrs?
Djballen is offline
Old 06-27-2008, 07:20 AM
  #1370
Davidka's Avatar
Trader Rating: 86 (100%+)
Rocco,
Thanks so much for sending those small parts (steering servo mounts) I got them last Friday and was able to race on Sunday. I really appreciate it.
Davidka is offline
Old 06-27-2008, 07:40 AM
  #1371
Dan Reino's Avatar
I am in the middle of a total rebuild of my 808. I cleaned the bearings inside the gear boxes, then instead of using light oil on the bearings for the Pinion gear, I used some real heavy 800 degree marine bearing greas and left all four seals off the bearings. I don't think the three screws have to be real loose, just tighten them down then back them off a little, seems to be working for me. I have 3 gallons on my car and it is still like new.
I did replace two center dogbone pins. Seems to be only thing that is wearing on the car
Dan Reino is offline
Old 06-27-2008, 07:43 AM
  #1372
anyone have any in stock?
josh_c is offline
Old 06-27-2008, 08:55 AM
  #1373
Steve Walters's Avatar
Maybe these guys still have a few...
http://hobbyroom.ca/pc-75318-92-xray...oad-buggy.aspx
Nope. I just saw they had them on back order...
Steve Walters is offline
Old 06-27-2008, 12:32 PM
  #1374
losi 8t's Avatar
Trader Rating: 13 (89%+)
does the motor mounts for xray xb8's...fit all the different types of xb8's?
i need a engine mount for and xb8...and was wonderin if anyone had one for sale? i really need one. gettin my xb8 tomorrow...and was hopin to get a motor mount here shortly for it.
let me know if anyone does have one tho. or where i can find one for cheap? thnx alot.
losi 8t is offline
Old 06-27-2008, 01:06 PM
  #1375
Default ACE Servo for Throttle Brake
Does anybody have any photos of there throttle setup with ACE 1015 servo as i cannot get mine right. The servo is quite tall and is about 1mm off the chassis (which i think is to close anyway) using the rubbers but the brake linkages are not parrallel to the servo horn and the connections to the brake cams.
when i try and set it it binds the brake cam arms and is sticking, the manual is no good either as it shows the arms set in different holes but i have tried all and nothing seems to work. The arms are perfect when they rest on top of the brake cams so it as if the servo is 2-3 mm to high but i can't lower it.
The photos i took haven't come out but i will try and get a better camera if needed
Cheers
Lunie
losi8lunie is offline
Old 06-27-2008, 01:14 PM
  #1376
Picture (up close, IN focus) is worth a thousand words....
Old 06-27-2008, 01:37 PM
  #1377
Regional Moderator
CarbonJoe's Avatar
The 808 mount is specific to the 808. The rest of the XB8/XT8 series use the same mount(s), either the two piece (stock) or the one piece mount (w/ engine specific rails).
CarbonJoe is offline
Old 06-27-2008, 01:56 PM
  #1378
I have tried to upload a photo but it says its 2 big (429Kb), does anyone know how they get the massive photos on.
Old 06-27-2008, 02:14 PM
  #1379
pm sent....
Old 06-27-2008, 02:15 PM
  #1380
Ok managed to do it i have left the horn off but you can see from the photo that the servo gear is a lot higher than the lower front brake rod. When i try and connec the assy it binds up and sticks.
