New XRAY 808
Old 06-03-2008, 07:31 PM
  #1126
Suspended
Trader Rating: 34 (97%+)
What if I lined the radio box and lid with some of that thermal tape? At least it would help keep some engine heat out. Never had an issue in my Hyper 8, but I used a Mugen radio box and the box is a little further from the engine, the regulator was a little further from the Rx in that box too.
FG101C is offline
Old 06-03-2008, 09:24 PM
  #1127
xlgraphicspro's Avatar
it's the lipo regulator and the lipo creating all the heat, in combination with the fast system. it will continue to happen. drop to a smaller lipo for more room. or switch back to a regular reciever pack. 2 guys at our track switched back, and haven't had a problem.
the regulator pumps off alot of heat. you can also mount the regulator outside of the reciever box.
xlgraphicspro is offline
Old 06-03-2008, 10:52 PM
  #1128
WheelNut's Avatar
I ran my 808 at a regional race last weekend and I've got to say this car is awesome!!!! The handling is so balanced, the jumping is smooth and full of "pop", and it is really really strong! Plus something like 8 out of the 12 cars in the A main were all 808s!
WheelNut is offline
Old 06-04-2008, 08:29 AM
  #1129
Trader Rating: 18 (100%+)
The 808 box is hot and some of the FASST receivers are overly sensative to heat. Mine has givin me lots of issues.
Is not limited to the 808. By that way I am not running lipo.
infanterene is offline
Old 06-04-2008, 04:53 PM
  #1130
slaytanic's Avatar
Trader Rating: 20 (95%+)
I'm getting ready to start my build soon. Does anyone have any specific tips that they found or issues to look out for?
slaytanic is offline
Old 06-04-2008, 05:19 PM
  #1131
Powerlink's Avatar
Make sure to sand and CA glue your carbon fiber parts ahead of time so there dry and ready .
Powerlink is offline
Old 06-05-2008, 07:02 AM
  #1132
Slaytanic - After having one for 4 race weekends, I would say go with 5-5-4 in the diffs rather than stock. Also, the wing mount has four mounting screws that go through the shock tower......with the lower two screws going through the tower then terminating into plastic. If you use a longer screw, it will go through the plastic far enough to put a nut on each screw. Do this. The wing mount will get loose after a couple of races.
toolmbx6 is offline
Old 06-05-2008, 05:19 PM
  #1133
Powerlink's Avatar
"The wing mount will get loose after a couple of races"..This has not been the case for mine .Anybody else seen this ?
Old 06-05-2008, 06:25 PM
  #1134
rregl0612's Avatar
Trader Rating: 33 (100%+)
Originally Posted by slaytanic
My GOD! You finally made up your mind! JFWY! Hope it does ya right. Heard they are tuff.
Anyone recommend a good cheap lipo setup for the 808? My helotes packs will work but I would think moving all that weight to the outer part of the chassis would not be a good thing. Or am I wrong?
Losi regulator and the venom 1600 flat pack have been working well for me!
rregl0612 is offline
Old 06-05-2008, 06:37 PM
  #1135
Trader Rating: 22 (100%+)
Originally Posted by Vigilante212
I think quite a few people were having issues with the faast system overheating. Not just in the 808 can someone confirm this im not 100% sure.
At one of the races, I left a FASST receiver out in direct sunlight while tinkering with my car. It was quite hot outside.
When i put it back in, I would get no TX\RX response.
I used a spare and put the 'hot' receiver by a cooling fan and it worked later. so there are heat issues definitely.
phixd is offline
Old 06-05-2008, 06:56 PM
  #1136
losi 8t's Avatar
Trader Rating: 13 (89%+)
Ok, enough is enough.......I was at my LHS today....and all they were talking about was the 808...if someone could contain me about this buggy...i would really like to look forward into getting one....what am i looking at price wise for the kit? and wat would be a good setup to use on a loose dirt, short...lots of jumps track?? idea's would really help me guys. thnx.
losi 8t is offline
Old 06-05-2008, 07:26 PM
  #1137
Vigilante212's Avatar
$600 plus tires, rims, electronics, engine, and pipe with header. The Stock setup works quite well and I would start with that and go from there to suit your driving style. I havent changed it yet because it works for me.
Vigilante212 is offline
Old 06-05-2008, 07:28 PM
  #1138
losi 8t's Avatar
alrighty then, ill stick with the stock day view....hopefully i can jump on the purchase VERY SOON.
losi 8t is offline
Old 06-05-2008, 07:46 PM
  #1139
pl_unc86's Avatar
Trader Rating: 17 (100%+)
I just wanted to confirm that the Avid Indo brakes for the xb8 or xb8r will fit on the 808. I know i read somewhere they would, but i just wanted to confirm. Thanks
Here is the link
http://www.avidrc.com/shop/?action=i...&pr evstart=0
pl_unc86 is offline
Old 06-05-2008, 08:21 PM
  #1140
pl_unc86's Avatar
Anyone that can answer my question?
pl_unc86 is offline
