New XRAY 808
#1081
can u run EC sway bars on the 808? im wanting a 2.2 rear sway bar prolly like most are lol
#1083
Haven't seen a thread made for a kit build project, so here's my XB808 I bought at Fastcats last week at a very reasonable price of $599+taxes is well worth every penny. Talking to Pam and John they will be supplying many parts for this buggy!!
I was very impressed by the packaging allow and after opening the box I realized that this was going to take a while, so I made some coffee and laid out the bags...
first the diffs... standard assembly accept for the cups to cap and space the bearings in the case, should keep the bearings nice and clean! Also the direct CVD drive is a great feature
now the arms and sway bars assemblies. the premium high-grade graphite shock towers will reduce weight slightly, but to help strengthen the graphite; sand and apply CA glue to all the machined areas!
after the front and rear suspension parts are assembled double check you have used lock-tight where instructed and all fasteners are secure! Now install on the chassis...
the RX and battery box is the same as the XB8ec, although the graphite servo tray has been improved and redesigned. also notice that I've replaced the plastic center diff brace that the one off the XB8ec model... (the wing brace, fuel tank, complete center diff assembly) are all a direct fit!! and I bet theres more, I will post when I fine them!
and finally the shocks and the rubbers... during the build I used THIS setup sheet, for the better part its a general setup for most tracks we visit...
Sending the body out this week for some custom work and also hit the5 for some early practice and setup changes (if necessary) and get some videos posted of my new ride!!
#1084
All i have to say is that this buggy handles like a dream and cut 2 seconds off my fast lap at my local track! GREAT JOB XRAY
...cant wait till next time!
#1085
Has anybody that has some time on there 808 noticed the front drive lines scrubbing the front out drive cups under full compression of the front susp.? I have noticed today the out drive cups are scrubbing the drives pretty bad . Do I need to install some fuel tubbing on the bottom of the shock shaft to limit the uptravel ? Or any other Ideas guys?
#1086
now when you say front drive lines, do you mean the front drive shafts? I'll re-post after I check it out
#1088
#1089
Ok, yeah. now I see. the front out-drives are chaffing the drive shafts at full compression. I think I'm gonna put 2 O'rings at the bottom of the shock shaft to limit the down travel about 1mm should be enough.
I have my front shocks in the upper farthest out hole, so it's as low as it can go. inner hole on the arm
#1090
sand the sharp edge off the graphite, not too much, and apply some tire glue to it. thin glue soaks in a bit, so let it dry after one application. then reapply. the thin stuff will flow down the edge, so apply it and rotate the part as the glue starts to run down the edge, this allows you to get a smooth rounded edge.
and the wing mount it screwed to the rear shock tower, but the rear chassis brace is directly opposite the wing mount, and the shock from a crash is diffused by the chassis brace.
#1092
#1095
