New XRAY 808
Old 05-29-2008, 07:25 PM
  #1066
Crim3Wav3's Avatar
well...dont i feel "special"
i didnt even think to look
Crim3Wav3 is offline
Old 05-29-2008, 08:55 PM
  #1067
Steve Walters's Avatar
Originally Posted by rmargiotta
We had a small amount of the cars come in today, so check your local shop to see if they have one on order.
Rocco, when will those be shipped out to the dealers?
Steve Walters is offline
Old 05-30-2008, 03:54 AM
  #1068
hi
where can i find a xb808 kit that sends international? need it sent to Australia..
amain out of stock
rcplanet doesn't stock xray
tower hobbies not stocking
and other webistes dont have international post options...
thanks
pracy is offline
Old 05-30-2008, 04:27 AM
  #1069
XXXRAY's Avatar
Im sure the australian distributor is expecting 2nd batch in the next 2 weeks and im led to believe that the pricing will be lower s well Hope this helps you pracy
Craige
XXXRAY is offline
Old 05-30-2008, 06:52 AM
  #1070
slaytanic's Avatar
Trader Rating: 20 (95%+)
Originally Posted by Crim3Wav3
ebay or the "for sale" section come to mind
How insightfull.
slaytanic is offline
Old 05-30-2008, 07:21 AM
  #1071
jpz_67's Avatar
Trader Rating: 57 (100%+)
Rocco, did any option parts make it in? Mainly the eccentric pin holders.
jpz_67 is offline
Old 05-30-2008, 07:29 AM
  #1072
Well, I got my 808 up and running yesterday, was just wondering how much play the mesh should have for the motor? Is there a trick or guideline for proper distance? I am coming from 1/10th electric and always liked doing the paper method until I got used to the feel. Thanks in advance!
Shu
shu88 is offline
Old 05-30-2008, 08:22 AM
  #1073
Crim3Wav3's Avatar
Originally Posted by slaytanic
How insightfull.
I thought so...
Old 05-30-2008, 08:37 AM
  #1074
Powerlink's Avatar
Shu
Your method should work fine thats what I also do. Just recheck the mesh after some run time , the gears will wear in a little
Powerlink is offline
Old 05-31-2008, 08:12 AM
  #1075
Rocco, you have a pm...
Wayne3 is offline
Old 05-31-2008, 09:33 AM
  #1076
mremtr's Avatar
I bet you do..........
mremtr is offline
Old 05-31-2008, 09:41 AM
  #1077
Crim3Wav3's Avatar
Thanks Keith!
You get that crank yet?
Old 05-31-2008, 12:14 PM
  #1078
mremtr's Avatar
Yes I did, in fact I got 2 for the price of 1 ! and only $68 shipped!!
mremtr is offline
Old 05-31-2008, 07:32 PM
  #1079
CAR
I needed three degrees of rear anti-squat on my 808.So I took the front hinge pin mount off my EC took a dremel and used it on the center of the aluminum plate to make it fit and then took the plastic bushings and drilled a threw hole in them so the pin would slide thur.I was worried about the rear toe piece with a straight hole that it wouldn't like being at an angle that the arms would bind up but they don't at all.Now I have 2,3or 4 degrees of rear anti-squat.I did not see if the rear toe piece or any of the front hinge pin holders would fit from the EC.
CAR is offline
Old 05-31-2008, 09:10 PM
  #1080
Greg M's Avatar
Interesting, I have a spare set of suspension holders for an EC as I had them on my XT8 but have changed back to plastic. I could pull my car apart to compare, but what is the difference between the 808 and EC holders?
Greg M is offline
