New XRAY 808
Old 04-21-2011, 09:51 AM
  #10261
Gizmatron's Avatar
Originally Posted by aussies1129
so I thought that I should opened up the packet which has the XRAY Aluminum Labyrinth Clutch Bell Dust Cover and give it a try on the 16t xray bell that came with the 2011 kit today. bugger me dead I just could not get the bell to spin free after shimming the end etc etc has anyone had this issue
Hi aussis1129 I posted about this a while back..the dust cover needs a lot of crank protruding beyond the clutch bell to spin freely..at least 1mm..I usually run 2 x 0.5mm shims behind the flywheel but had to remove both for it to work..
Gizmatron is offline
Old 04-21-2011, 02:11 PM
  #10262
aussies1129's Avatar
Trader Rating: 74 (100%+)
aha ok I thought it was the other way ok so did you still shim the front aswell? I have at least 1mm so it should be ok. cheers
aussies1129 is offline
Old 04-21-2011, 03:46 PM
  #10263
grizz1's Avatar
Hi Michael, I had a little struggle with the shimming too. Got it sorted after 20 min or so. Ran the cover for a few meetings and it seemed to work ok. The outer bearing didn't get as dust clogged as usual for sure.
Ahh, not trying to be funny, but you are running the V2 bell with the lip for the dust cover eh ? I'm sure you are, but I just thought I would ask anyway ......
grizz1 is offline
Old 04-21-2011, 03:58 PM
  #10264
bcr500's Avatar
Trader Rating: 34 (100%+)
Originally Posted by ELAD .Z.
Hey guys what punisher body will fit best the 2011 car?
Not sure about the punisher on the 11 spec, but I know people run the bulldog for the mbx6 and d8 on there 10 specs, so I would think the punisher for one of those brands would work ok.Also I think I read somewere that the d8 was the better fitting of the two. good luck
bcr500 is offline
Old 04-21-2011, 08:13 PM
  #10265
hey mate I think so thats the 16t that came with the 2011 car it protrudes out abit not like the other bells so i take it is the v2. I will spend some time on it today. thanks!
Old 04-21-2011, 11:55 PM
  #10266
grizz1's Avatar
Yep, thatīs the V2 bell. I found I actually needed less shims rather than more shims because of the protruding section on the dust cover. It sort of acts like a crank extension.
grizz1 is offline
Old 04-22-2011, 08:27 AM
  #10267
asaraneta's Avatar
Guys,
Any updates on XB808 2011 conversion kit? Is Xray going to have this conversion kit out commercially in a very near future?
Cheers
asaraneta is offline
Old 04-22-2011, 09:17 AM
  #10268
Feeling a bit nostalgic, I went through the first 10+ pages (for the nth times!)) of this thread which goes all the way back to 2008, I wonder what happened to all those haters?
ganymede is offline
Old 04-22-2011, 02:50 PM
  #10269
Trader Rating: 32 (100%+)
Originally Posted by asaraneta
Guys,
Cheers
I would only assume so since there is a 2010 conversion kit, but who knows.
mcion is offline
Old 04-22-2011, 05:05 PM
  #10270
nitrojamie's Avatar
Hi guys im here in New Zealand their is a conversion kit out now to convert a 2010 to 2011spec but its not cheap.I was going to convert my 2010 car but the conversion kit was going to be more than half the price of a new car so i thort stuff it and brought a new car.I geuss the conversion kit if so dear because its got so much in it like body,drive shafts,pinions,gearbox casings,hinge pin holders,chassis etc.
nitrojamie is offline
Old 04-22-2011, 05:57 PM
  #10271
I had a punisher on my 2010 spec and i had to heat the sides up a lil with the body on to make it conform to the vehicle.
mcion is offline
Old 04-22-2011, 06:24 PM
  #10272
bigmatt's Avatar
Trader Rating: 16 (100%+)
what is any body using for a battery in the 2010 808. I want to use life batts but am using savox servos. and they are power hungry.[1257x2] I have 2 lipo's one is 2100mah other is 1200 that barely lasts 20 min. and is very unreliable.
bigmatt is offline
Old 04-22-2011, 07:21 PM
  #10273
vince7870's Avatar
Trader Rating: 15 (100%+)
amain protek 2300 lipo,,,,last an hour for me with hv servos
vince7870 is offline
Old 04-22-2011, 07:32 PM
  #10274
bigmatt's Avatar
how long have you had the pro-tec? Thats one I use. It barely fits the box and the outer cover is wearing off.
bigmatt is offline
Old 04-22-2011, 08:02 PM
  #10275
vince7870's Avatar
i used a dremel sanding wheel inside the battery compartment box. i opened it enough so it slides in and out freely
