New XRAY 808
Old 02-03-2011, 09:40 AM
  #9226
pickle311's Avatar
Trader Rating: 31 (100%+)
Originally Posted by BuggyKing
What is this overdrive pulley you guys seem to like so much. Do you have a link to it.
It's the 41t Diff gear for the front diff.
pickle311 is offline
Old 02-03-2011, 09:41 AM
  #9227
mmaattppllaayy's Avatar
Trader Rating: 35 (97%+)
its the 41 tooth front ring gear. You can get one for the active diff and the regular diff.
mmaattppllaayy is offline
Old 02-03-2011, 09:45 AM
  #9228
Originally Posted by Gizmatron
By the way anybody notice that the photo of the radio tray on it's own isn't the correct one? it's still the old photo ...look at the photo of the car showing the drivetrain with a transponder in place...totally different tray..ooops xray..
That picture is the one of the 2009 spec model when they won the car of the year as shown in the bottom of the pic. Dont know why they posted that but o well drrrdeedrrr.
And your right about the radio tray that one in the pic doesnt have a transponder mount maybe thats what the new radio box is. Maybe some super secret transponder mount since your not supposed to mount a transponder directly to any carbon surface. It can glitch the signal. If your using the new rc4 mylaps like me though it doesnt matter cause it has a plastic mount to separate it.
Old 02-03-2011, 09:55 AM
  #9229
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Is it difficult to shim out for the 41t ring gear.
BuggyKing is offline
Old 02-03-2011, 10:05 AM
  #9230
bcr500's Avatar
Trader Rating: 34 (100%+)
No it is not.I swapped my 43 to a 41 and it dropped str8 in without reshimming.
bcr500 is offline
Old 02-03-2011, 10:10 AM
  #9231
Cade's Avatar
I am very excited about the new buggy and I expect great things out of it this racing season!
Does anyone know if the "Bubble Body" will fit on the new buggy?
If anyone is at the car show they should snap us some pics!
Cade is offline
Old 02-03-2011, 10:18 AM
  #9232
BuggyKing's Avatar
Ok thx for the info.
Old 02-03-2011, 10:20 AM
  #9233
BuggyKing's Avatar
anyone try running 41t all around. Did u see any difference.
Old 02-03-2011, 10:31 AM
  #9234
That would be the equivalent to just putting a bigger clutch bell on just makes it have more top speed. Not suggested to do that. All the 41t gear does is make that diff spin faster which when on the front makes the front pull the rear around which is what gives the perceived extra turning. I just run the active diff in the front with the stock 43t gear and thats all the steering i need otherwise the buggy gets a little unpredictable.
Old 02-03-2011, 10:32 AM
  #9235
ronsand's Avatar
You could, but I don't see the point other than to change the internal or final gearing. That is in any case done easier and cheaper by changing the center spur gear and/or the clutch bell.
You beat me to that one Matt
ronsand is offline
Old 02-03-2011, 11:00 AM
  #9236
rfleck's Avatar
Trader Rating: 58 (100%+)
Originally Posted by jonw
Thanks Ron, I am going to try one on Cade's buggy, I guess my other question would be will it work with the new drivetrain?
Hey Jon,
I would presume it would work with the new drivetrain. The new pinions are essentially the same as the XT8. I honestly don't think I will ever put the standard 43 tooth back in my buggy for the front diff. I like the overdrive that much.
Also, there are two different 41 tooth gears (one for active diff, other is for regular)
Cheers,
rfleck is offline
Old 02-03-2011, 11:19 AM
  #9237
Two-speed's Avatar
Trader Rating: 24 (100%+)
When does it ship?
Two-speed is offline
Old 02-03-2011, 11:23 AM
  #9238
jonw's Avatar
Originally Posted by rfleck
Hey Jon,
Cheers,
Was told the new gearing would require a different size ring gear. Definately going to order one for our current buggy. Thanks for the help.
We run the active diff in the truggy and Cade really likes it.
jonw is offline
Old 02-03-2011, 11:58 AM
  #9239
RC America's Avatar
Because we are returning to the traditional pinion style, there are some different options with the gearing.
The kits will include the 43T ring gears and 10T pinions, so any existing 808/XT8 overdrive gears (41T) will drop right in.
We will also be able to change to the old 40T/12T ring/pinion with a larger spur. This will change the car's throttle response and power distribution, and give some added tuning for different conditions. If the 40T/12T setup is used, the old overdrive gear (38T) would be needed.
As mentioned above, the Active diffs require a different ring gear (whether it is the 1:1 ratio or overdrive).
Anyone confused yet?
Bryan
RC America is offline
Old 02-03-2011, 12:29 PM
  #9240
Gizmatron's Avatar
Originally Posted by mmaattppllaayy
And your right about the radio tray that one in the pic doesnt have a transponder mount maybe thats what the new radio box is. Maybe some super secret transponder mount since your not supposed to mount a transponder directly to any carbon surface. It can glitch the signal. If your using the new rc4 mylaps like me though it doesn't matter cause it has a plastic mount to separate it.
scroll up the photos and look at the one of the entire chassis showing the center drivetrain and that pic shows the new radio tray complete with the PT mounted.the pic of the tray alone is just the wrong photo period...
Bryan
yeh but if you go with the old 40/12 setup you also need to go back to the 46 (or was it 48) tooth center pinion which will almost certainly involve raising the diff mounts for clearance underneath.I thought the whole point of the 42T pinion was to lower the CofG..or you need to drop to a much smaller clutch bell and I'm not sure you can go below 15T and still fit the larger xray 5x12 bearings in..would have to go to 5x10 like everybody else..
And I'm always gonna hate the cvd's with not one but TWO sodding screws that can work loose..Unless I suddenly have grave probs with my center bearings(doubtful as they were fine all last season) I'll probably buy the new alloy F/R steering hubs and supports (which remain option items anyway) for the increased adjustment range and leave it at that.
Not really wowed by any of the other changes.But then I didn't have any great probs with my 2010 anyway..still the fastest and hardest to break buggy I ever drove.
Gizmatron is offline
