New XRAY 808
Old 12-28-2010, 03:52 PM
  #8881
aussies1129's Avatar
Trader Rating: 74 (100%+)
Originally Posted by mcion
Thats expected I would think since you since you makes for less resistance against uptravel. I know a few that do that to get better uptravel.
I was referring to the shock socks that aussie is using.
no effect they are just a lycra sock that goes over the spring and the excess at each ends just tuck back into your spring and just install your spring from there the spring fits firm on the tension cap and perfect on your lower cap and my shock get no where near the amount of crap as usual and they wash easy back to new looking, I still have my boots on but you could remove them if you wanted?
happy new year to everyone look forward to running xray in 2011!!!cheers
aussies1129 is offline
Old 12-28-2010, 08:41 PM
  #8882
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Dont mean to hijack. Let me ask. Anyone have issues mounting JR servos in the stock location with mounts. Mine I just noticed the servo mounts for the chassis do not support a JR servo.
BuggyKing is offline
Old 12-28-2010, 08:56 PM
  #8883
Cade's Avatar
Default The new XRAY buggy!!!!
I am really excited about this buggy for the 2011 season. I still don't know if I should save up and get a kit or just upgrade from my 2010 buggy? I actually like the body, it is different!
Cade Whitenton
Cade is offline
Old 12-28-2010, 09:55 PM
  #8884
Jaz240's Avatar
Trader Rating: 52 (100%+)
Mathew, refer to the instruction manual. There are 2 types of servo mounts. You have to use the correct ones for JR servos. I don't remember if it's 2 thin or 2 thick or 1 of each.
Jaz240 is offline
Old 12-28-2010, 10:29 PM
  #8885
+1 to what Jaz said... Should not be a problem, check page 29 of the manual.
ganymede is offline
Old 12-28-2010, 10:57 PM
  #8886
BuggyKing's Avatar
ok thx guys, well I am building the car from the ground up so I am learning as I go
Old 12-28-2010, 11:54 PM
  #8887
mazmorbid's Avatar
Trader Rating: 11 (92%+)
From memory with JR it's 2 thin ones
mazmorbid is offline
Old 12-29-2010, 05:12 AM
  #8888
vince7870's Avatar
Trader Rating: 15 (100%+)
I jr hv's. It was tight but worked fine. I believe it was 2 thin ones as well
vince7870 is offline
Old 12-29-2010, 05:19 AM
  #8889
Zerodefect's Avatar
Wow, I didn't know anyone still ran JR servo's. When JR says "servo" they're usually speaking in past tense.
Don't forget to subtract a shim or grind it down to make up for the rubber squares thickness.
The Hitec shim is the same thickness as the rubber squares, so I use no plastic shims.
Zerodefect is offline
Old 12-29-2010, 12:31 PM
  #8890
rfleck's Avatar
Trader Rating: 58 (100%+)
Default need more on power steering
Guys, I have a 2010 model in which I have modded the drivetrain. I run on a tight technical,semi high traction track. I run the overdrive front gearing. Currently the car has great off power steering, rotates nicely with the camber links as short as possible on the rear, but on power seems a bit weak. Running 7-7-5 in the diffs. 28mm front and 30mm rear ride heights
Any suggestions?
rfleck is offline
Old 12-29-2010, 01:16 PM
  #8891
BuggyKing's Avatar
Any suggestions?
I sent you a pm.
Have you tried adjusting kick up. Running less will increase overal steering.
Old 12-29-2010, 01:23 PM
  #8892
BuggyKing's Avatar
you can test a thinnner swaybar up front but might increase track rolling.
Old 12-29-2010, 01:46 PM
  #8893
Zerodefect's Avatar
Any suggestions?
Stiffer rear springs
Thicker rear diff fluid, then possibly thicker center fluid
Move the front arm wheelbase adjustment back, shorter (huge steering increase)
12 degree caster blocks
More rear camber -3 to -5
Go back to the stock diff.
Tires
Old 12-29-2010, 02:06 PM
  #8894
Poltro's Avatar
Originally Posted by Bren Ralls
hudy spare pin for drive shaft tool
#DY106035 - EJECTOR PIVOT PIN
Thanks!!
Poltro is offline
Old 12-29-2010, 02:46 PM
  #8895
Trader Rating: 32 (100%+)
Any suggestions?
Are you shocks mounted in middle position? You can try a softer front spring. Normally though I would not go softer than Silver though. What piston and front oil are you using, you can lower front piston oil weight and go with a 5k in the front rather than a 7k.
mcion is offline
