New XRAY 808
Old 12-09-2010, 12:48 PM
  #8761
Originally Posted by R.M.S
hey guys, i'm trying to set the droop on my xb808. the setup sheets i'm using use a height gauge to set droop, but i'm used to measuring center to center on the shocks for my losi. does anyone know what the center to center shock length should be on the xray? Thanks
General start point is 104mm front & 114mm rear measured centre to centre.
Bren Ralls is offline
Old 12-09-2010, 12:59 PM
  #8762
Trader Rating: 32 (100%+)
Is that max available with xray shocks while resting on droop screw.
mcion is offline
Old 12-09-2010, 03:41 PM
  #8763
mmaattppllaayy's Avatar
Trader Rating: 35 (97%+)
so besides drivetrain changes what can be expected for the 2011 kit? Just general areas of improvement you dont have to divulge too much info I just would like to know what basic areas other than the drivetrain. This is going to be one of the big years for xray hope they get it right.
mmaattppllaayy is offline
Old 12-09-2010, 03:44 PM
  #8764
Suspension Geometry.
mcion is offline
Old 12-09-2010, 03:59 PM
  #8765
BuggyKing's Avatar
Trader Rating: 17 (100%+)
are you guys just running the stock bearings in the car. I wanted to run a higher quality bearing, but not sure if they hold up better.
BuggyKing is offline
Old 12-09-2010, 04:05 PM
  #8766
There are numerous posts in the last 3 or so pages. Including pics of the new-Parts.. and there are some other small changes to the 11..
jamiekerr14 is offline
Old 12-09-2010, 05:01 PM
  #8767
the only things i saw were about the new hubs and drivetrain
Old 12-09-2010, 06:16 PM
  #8768
cool, Thanks
R.M.S is offline
Old 12-09-2010, 07:14 PM
  #8769
Trader Rating: 7 (89%+)
Avids revolutions are great. Dont go wasting your money on ceramics for the bulkheads cause you need to load it up with grease so it defeats the purpose of going ceramic. Just buy the 1 dollar a piece bearing ang youll be great.
oggietiu is offline
Old 12-09-2010, 07:22 PM
  #8770
BuggyKing's Avatar
You guys run a lot of grease on the bearings. Do you guys run the graphite grease on the pinions.
Old 12-09-2010, 07:26 PM
  #8771
I use lithium. I use to pack it with the stock drivetrain, but now I just dab a bit with a q-tip. really quiets the drivetrain and makes it very smooth.
mcion is offline
Old 12-09-2010, 08:30 PM
  #8772
BuggyKing's Avatar
Litium grease. What brand do you have a link to it.
Old 12-09-2010, 10:55 PM
  #8773
I do not normally measure this way but from memory max was Fr 105mm & R 115mm.
To add some strength to the rear it has no groove & to get more droop I replaced the stock ball joint with the older EC steering link ball joint. Cant find the number any more but the bore is correct dia & good fit, but like i said slightly thicker & longer to achieves masses more rear droop if needed.
Old 12-09-2010, 11:18 PM
  #8774
http://www.youtube.com/watch?v=MKy1DhSo9g0
Links covers what your asking in grease tip, & like mcion any lithium based grease. Its cheaper to buy from a automotive store in a tube. THe grapite grease is meant for the axle & drive shaft pins.
Old 12-09-2010, 11:28 PM
  #8775
BuggyKing's Avatar
Thank You for the vid. Makes perfect sents.
