New XRAY 808
Old 11-12-2010, 01:01 AM
  #8446
Bren,
Are you in Pattaya? Anything interesting to share with us?
So the toe block is longer and the arm shorter?
ganymede is offline
Old 11-12-2010, 01:17 AM
  #8447
I can see page 564 but can't seems to be able to access it... Anyone experienced the same thing?
ganymede is offline
Old 11-12-2010, 01:19 AM
  #8448
Wait a minute! I am on page 564! Lol!
ganymede is offline
Old 11-12-2010, 01:21 AM
  #8449
Gizmatron's Avatar
I was having the same problem...rctech glitch I guess
Gizmatron is offline
Old 11-12-2010, 01:22 AM
  #8450
aussies1129's Avatar
Trader Rating: 74 (100%+)
Originally Posted by razo125
I don't think he is using the mugen (button head droop screws.) Looks like they made some mods to compensate for the different rear arm mounting position. Buttonhead would catches the bottom of the chassis, it appears they used lock nuts.
whats the cut out in the side mud guard for?
aussies1129 is offline
Old 11-12-2010, 01:24 AM
  #8451
Throttle and brake servo...
ganymede is offline
Old 11-12-2010, 02:41 AM
  #8452
didnt see that on mine is that the 2010 side guard?
Old 11-12-2010, 02:46 AM
  #8453
He probably cutout the side guard to give more clearance to the servo, I have to lift my servo slightly to clear the side guard... No biggie...
ganymede is offline
Old 11-12-2010, 04:53 AM
  #8454
Gizmatron's Avatar
I believe they are testing a lower servo mount position to lower CofG..hence the cut out for the edge of higher power servo's which are taller.Personally that's not a position I'd like to put my expensive servo's in.More chance of a direct hit or water getting in.I'm sure my driving won't get any better cause my servo's are 1 or 2 mm lower
Not sure what difference the shorter arms would make to the handling etc but i do like the idea of the longer toe/anti-dive blocks giving more mud clearance between the wishbone and the diff housing.I'm forever picking crap outta there between races.It's worse at the front though and I don't see any changes there in the photos.
Old 11-12-2010, 10:56 AM
  #8455
yeah if you run at a track that has the slightest rock sticking up and a direct hit to that servo could be a problem I doubt if they have that problem there thou
Old 11-13-2010, 01:06 AM
  #8456
Originally Posted by ganymede
Bren,
unfortunately not in Pattaya but wish i was as track looks a blast technical & very rewarding when you get it right.
Things to share in bits you have seen & talking abought here are tweaks & refignments to what you saw on my car a month or so back. The guys at the worlds would of recieved a pack of parts which I also recieved which all look very smart. You have all seen Juraj's car pictures posted & a tweak to the drive train which is what many have wished for & gives options.
Although the hubs etc that i had originally proved reliable the new parts are beefed up in the right places so durability will never be a problem.
The new front hubs will give more steering but dont fret if you think your current car has enough, it produces more where you need it & as a usable product so just compliments the car more.
The rear end & wishbones helps in cornering, bumps & landing again just little tweaks.
All in all hitting the points where the car often struggled.
There are various other points but i wont let on, its more fun to just sit back & see what you all come up with here..
Bren Ralls is offline
Old 11-13-2010, 04:38 AM
  #8457
F Duct?
jamiekerr14 is offline
Old 11-13-2010, 05:23 AM
  #8458
Bren,
Thanks for the update! Knowing XRAY, I bet the upcoming 2011 spec will be even better!
We often curse the angle of the drive shaft relative to the center diff, I wonder how the Durango 408 does it? They move the center diff so far off the center line, the fuel tank is almost in the dead centerline of the chassis!
I don't think there is a need for the 808 to have a major revamp, improve its durability (pinion bearing, pinion bearing and pinion bearing), new drive train, SEALED bulkhead, stiffer chassis and adding a few option parts (to the kit will be golden...
ganymede is offline
Old 11-13-2010, 02:01 PM
  #8459
mmaattppllaayy's Avatar
Trader Rating: 35 (97%+)
Looks like Josh Wheeler is either running the mugen bulldog body or is using a new proline one soon to come out. Surikan C. was also running the white or gray colored boy below
mmaattppllaayy is offline
Old 11-13-2010, 03:52 PM
  #8460
linerv's Avatar
Kyosho shocks on Josh's xray?
linerv is offline
